A few weeks ago I was riding and my motorcycle started making a horrible rattling noise. sounded like something broke loose and was bouncing around somewhere in the engine.
Removed oil, noticed bronze and metal flakes, but hadn’t changed the filter in awhile and the oil was old.
Took apart clutch to look inside and see if anything was loose or messed up, it looked okay, so I put everything back together, new filter and new oil started it up and had a little rattle at first, but that went away shortly. Let it run for a bit, sounded good.
Thought everything was good until I went for a test ride, immediately in first gear I noticed a drop in power, slow rev which wouldn’t get above 7k rpm, rattle returned..made the block and tried to listen where it was coming from (sounded like the front) before shutting it down.
motor was really hot (way to hot for the little test ride).
Haven’t started it back up yet.
Any thoughts ? Where do I begin?
