Hi Cleve,
I've got exactly the same problem. I've even fitted a new battery and starter relay to no avail.
Have you found a solution as yet?
Cheers,
Tony
Oh, as an aside, I jump started the bike by bypassing the starter relay. Above 2000rpm, all the dash lights come on, Below 2000 rpm, they all go off again. I did this several times with exactly the same result. I'm not sure why the RPM makes a difference...
