No instructions that detail which each wire is for? If not, then just use a jumper wire to give each pin 12v power to determine which is which. Typically black would be ground, so I would run ground to the black terminal then apply 12v positive to each of the other pins one at a time to see what function lights up. I would expect red to be taillight/running light.
