1 - 14 of 14 Posts
I got the universal fender eliminator from eBay for about $40. Put it on today and it took me about 2 hrs. It didn't have the plug connectors for the lights so I had to cut the tips and just directly wire them. The license plate light works perfect however the blinker not so well. They work but the don't flash. It's just a sold light when I use them. It's also solid in the dash too until I turn them off. Anybody know what I could of done wrong? This is my first bike and I don't know much about working on them. I really like the way the kit looks tho. So much better than the stick mud flap. If anybody could give me a few pointer on fixing this that would be great. Thanks
Either you spliced the wiring wrong or one of the lights is messed up do some trouble shooting and you should figure it out I had the same problem had to splice my wires 3 diff times till I got a good solid proper job done (it was my first time ever doing this
Discussion Starter #9
Forgot to mention this. I cut the little tips of the stock fender lights and just wired them to the new lights then I just plugged them into the bike. Could this be the issue?
If its not a good enough connection then yes it's the issue it happened to me cause I failed at it 3x there's an article that helped me ill see if I can find it so u can try it out I had the same problem and it was driving me insane ,
If you have smaller, lower draw bulbs, even regular incandescent/non LEDs, you may need the new electronic relay. Search relay, or my older threads, the part number is listed there and it is under $8 at any auto parts store. If you mis-wired it I can't help you, each signal has 2 wires, hard to mess that up! :D
Also make sure that you have a proper earth (negative) as that can cause them not to flash too....
1 - 14 of 14 Posts
