I was looking into fabbing some billet bar risers (spacers for the stock risers) also called lowering kits, and found some really nice ones for 50-60 bucks on ebay but after pulling factory ones off and seeing that they dont clamp onto the top of the fork I came up with this and it works great.
First, I was not interested in lowering the bike, just trying to bring the bars a little closer to me.
I found that 3/8 is as far as you can raise the stock risers and keep the fork tube underneath while not raising the forks in the clamps/lowering the bike.
I went to ace and picked up some longer stainless steel bolts and some 3/8 thick collars and installed them. I was happy with how solid it felt so I pulled the bolts, put on some blue locktite and re installed them. The collars have set screws that you can run into the bolts after tightening them and if positioned correctly will eliminate any twist. cost was about 17$. Time was about a beer and a half. feels very solid and will still allow lowering/raising the forks if that was your intention. I also found 1/2 and 1" spacers that would work fine if you wanted to go higher and would allow for that much more lowering of the front by raising the forks. I like the way the bike sits and handles so I stuck with these so the risers would not be above the top of the fork
