FWIW, I am inclined to believe the clearance between valves and pistons in this engine is quite spacious - all things considered.
For example, my cam chain is stretched enough that when I set my timing I have to count the links exclusively, because the timing marks are so retarded they don't like up with the valve cover mating surface anymore. And I had (and still have) no signs of valve to piston contact. So honestly if I was you I'd probably have gone the last 2 thou down on the head.
I also found what you did setting the camshaft timing. Yes it kinda binds, but I just follow the book and it works out every time. It does feel a bit bad crushing down those cast aluminum caps, but it works and doesn't damage them any real amount. I put a good big dose of assembly lube on them when they go on. Keep in mind engines with more cylinders require that valves are opened when you install big long camshaft caps, it's just part of the assembly. Doesn't make it feel less bad though when you are taking a ratchet to the cap bolts though. I do multiple rounds of torqueing the cap bolts. By hand with no wrench (just a socket and extension), very lightly with a wrench, until the bolts bottom out, then torque to spec. But that's just how I do it.
Did you hone the cylinders before measuring the bore? I didn't even bother to measure mine, but also mine never overheated, so I just ran with it and was unwilling to buy a new cylinder regardless, and it worked out in my case. I lapped my cylinder and head with a glass plane, and also didn't even bother to measure the clearances - and it all worked out perfectly. I was thinking, I wonder if there was a thicker head gasket should you lap down your head too far, but you probably don't need it.
Looking like great progress.
