1 - 20 of 35 Posts
I'm looking to put some new grips on my 300 but don't want to cut the grips off and don't have an air compressor. Are those the only 2 options to changing the grips?
Should cut them I went and bought new grips today only 15$ from a proper store you could get them so much cheaper eBay/amazon etc...
Sent from my iPhone using MO Free
I used a long thin screwdriver and worked it all the way around the bar to break the glue loose and a shot of WD-40. Only takes a little bit and it slipped right off.
Used hairspray on the new grips. That give it some lube to go on the bar and some sticky to stay there when it dried.
Since I don't have a mechanics garage equipped with compressed air, I opted for soapy water and after the epic struggle my forearms looked like Popeyes.
Without air, I would try hairspray next time.
$10 isn't bad for improved grip with less vibration.
Cutting them off is much easier IMHO if you don't have a compressor. Use a razor blade and carefully cut almost through to the bar/throttle. You can then peel them off.
What if you have heated grip pads installed on there, can those be saved with injecting liquid in the grip to remove it? I'm hesitant to install my heated grips before the Fall. I don't have access to an air compressor.
Sent from Motorcycle.com App
I used windex and a screwdriver to remove my grips, and then hairspray when putting the new grips on. You definitely don't need to cut them!
Just beware you're going to need an impact driver (or a torch) to get the bar ends off.
Reactions: mburff
Always better off cutting the old and installing new, especially when they are so cheap (renthal grips are by far my favorite).
If you are using the heated pad that sticks to the bar then you'll need to pull up on one end of the grip and start cutting slowly, always keeping the part you're cutting off the bar.
For the non throttle side you should put a single layer of electrical tape on the bar before applying the heating pad otherwise the aluminum will steal most of the heat and the left side won't feel nearly as warm.
Ah thanks. It's a new grip I just put on. They were coming off easily yesterday when I sprayed windex on them. Now it doesn't budge. I don't want to cut those off yet lol
Reactions: Dark
Discussion Starter #12
have you had any issues with the grips slipping at all with the use of hair spray?
Discussion Starter #13
Get WD40 under the old grips using a thin flat head screwdriver. Work your way around and it should slide right off.
As for installation, use hairspray on the inside of the new grips.
I was told that you shouldn't use WD-40 due to it being oil based.
Discussion Starter #14
Wish I would've seen this sooner about the impact driver or torch. I've stripped the head on one screw :( and I'm not going to even attempt to touch the other one!
Discussion Starter #16
clean up afterwards with either "eucalyptus oil" or "tea tree oil";)
Oil sounds just a bit too scary for me :confused:
I think I will stick with what Kairus said about the windex
"eucalyptus tree oil" doesn’t leave any residue, its not an oil as such, its perfect for cleaning oil & sticky goo from sticky tape
they are native to Australia & this stuff is magic kit
http://en.wikipedia.org/wiki/Eucalyptus
go down about 1/2 way down the page & read about the "eucalyptus tree oil" & what its for
aussie's have been using it for generations:)
Discussion Starter #18
that's awesome! But heres another question. If I am going to be putting on clip-ons with new grips, do i still need to take of the old grips on the old bars?
Yes, because the throttle tube won't come off without the bar ends off.
edit: throttle TUBE
1 - 20 of 35 Posts
