1 - 4 of 4 Posts
Hey Guys and Gals!
New Ninja 300 owner. While changing my spark plugs, I accidently broke off the end piece where it connects to the throttle body assy on the right side of the motorcylce. The Hose itself is still intact but the little tube thingy(not sure of the exact name) has snapped off right where it connects to the throttle body I believe this is the place where the fuel goes. Question: Is this something I can fix by going to my local home depot and getting something to reconnect this piece or do I have to replace the whole part where this thing broke off?
115026
115027
115025
Thats not going to the throttle body, that's a fuel line going to the injectors it looks like. I may be wrong, but usually those type fittings are fuel lines, and there's no fuel going to the throttle body.
Yea I believe you are right, I think i can just replace the deliver pipe where the fuel line connects to the throttle body. Ive ordered a new throttle body either ways that comes with a new fuel line. so i hope i can just replace that part without having to remove the throttle body
Sorry to revive a dead post, but I think my contribution can be of some value to anyone else that ever encounters this issue. The part you are referring to is the Pipe-Comp, Fuel #31064-0164.
Basically if you aren't careful about disconnecting the fuel hose when removing the tank, this fragile plastic nozzle will break very easily and the motorcycle will become a very heavy paperweight. The injectors will not be able to deliver fuel to the throttle body and you'll end up spewing gas everywhere. I learned this the hard way.
Oh yeah, and the OEM part costs around $70, so there's that too...
1 - 4 of 4 Posts
