1 - 10 of 10 Posts
Ninja 300 WTE ABS, 06 CB599rr Hornet, 14 JCW ET3 RIP , 91 TR4 full body armor 11 WK2 230k
After I learned how to properly wheelie on the 300 and reterminate all of the loose wiring
I was wondering should this be an option?
I know some people in the Ducati forum do it.
Also I'm trying to find the a Revit tool to replace some parts on my body kit so I can quickly take off and on as like to clean / inspect the engine.
Any suggestions en lieu of the said tool?
I'm sorry but I have absolutely no idea what you are asking..what wiring? what tool? Can you be more specific?
My apologies,
Big 3 wiring any advantages it would have over the power system? In automotive I've gained lost power
I've seen costly kits but seem like a waste of money
2nd Question -
Body kit revit tools using revits and bolts to reinforce my bike
Context clu
Hello, and welcome to the forum, Motoviker!
Even with your second post which supposedly explains your first post, I too am pretty much clueless as to what you want to achieve. :unsure:
When you write "revit", are you potentially misspelling that, and it is supposed to read: "rivet"?
My best guess:
You are trying to replace the way the fairings are bolted/screwed/affixed to the bike, and want to make them easier to remove and re-attach?
And this involves some sort of modification to the threads/bolts/screws? Possibly using some kind of a "rivet tool"?
As for the wiring: here I also have no clue what you mean.
My best guess number 1:
With all the wheelies you are doing with the Ninja 300, the wiring is shaking loose, and you want to replace some of the wiring and/or connections to make the connections more secure, and the overall wiring on the 300 tighter & more 'compact' so it becomes less slack?
My best guess number 2:
You want to replace the wiring harness on the Ninja 300 to one which has no plugged connectors (but is some kind of connector-less direct wiring) to somehow increase the power the engine is transferring to the wheels?
Are those guesses close to what you're trying to convey?
To the marrow
Big 3 wiring for the Ninja 300
Revit tool can be retracted.
Regards
Okay, in that case I strongly suggest you reduce some glacka, because too much flasen will give understeer.
Marroq is okay, but revit now, before blartsenten crosses over.
Goid lucky!
Oh no more wheelies I just never did one on this bike "I try to push the bike down"
Big 3 was done on my buddies klr750.
Revit tools makes threaded studs and bolts
An ammo can that I can now easily take on and off the bike using the deleting back seat resets mounting points.
I got this answer from a shop where I live
I'm getting the correct one that can use rubber jackets studs for the body kit
Thanks in advance
Discussion Starter #8
My best guess:
OP--- Revit, I'm getting the correct rivet tool for my body kit.
My best guess number 1:.
OP, I'm all good
OP
----- Not replace brother, add a big three 3 without over taxing the integrity of said harnesses/motor.
Any performance gains is a plus.
Thanks
OP, I'm all good
OP
Big 3 Wiring: I thought that was just for audio, so you don't fry your factory wiring when installing a 60000W subwoofer.
How exactly is this supposed to increase 'performance' on a motorcycle?
Discussion Starter #10
Never said performance, byproduct maybe.
please read above, I've already calculated wire size and installed.
Wires corrode you can't see it.
I ride in rain.
Bikes age, wouldn't you want extra power to arc so your not stranded also I have extra relays in case of needing to switch on the fly.
My bud did it on his klr to add brighter lights.
I just was asking if anybody did it so I didnt have to calc wire size. Not for a half witted grammer lesson.
Not being an ass
1 - 10 of 10 Posts
