Hey folks,
My rear suspension has begun to feel.... bad. I suspect it is the swingarm bearings and linkages for the shock. They have never been lubed in their life, so I think it is time (or maybe past time unfortunately).
I think I just need a way to maybe chock the front wheel, and then jack up the oil pan with a wood 2x4 under it, yeah? In order to unload the rear suspension and get that all out right?
Just never taken a swingarm off a bike before, and figured if someone has some advice off the bat, I'd ask. I plan on following the shop manual procedure for lubricating the swingarm and shock linkages, as well as thorough cleaning of all the parts.
Hoping this will resolve the weird feeling before the track day this coming Sunday. The bike is feeling like it was vibrating more at certain RPM's and loads, but ran great still. I have been noticing my rear tire losing traction at odd times as well, and when I forcibly jump on the foot pegs to bounce the suspension, the rear seems to not move as readily as it once did. My front engine mounts I believe are rubber, and I do think they are worn, but I don't think that would cause the rear end feeling off, but maybe the vibrations. I did check the wheel bearings, cleaned and repacked. They are in great shape, no issues whatsoever. Chain tension is perfect as well, and in good enough shape. I thought the vibrations may be mostly originating from the engine, but I think it is actually the ground undulations coming through in the seat of the pants more, due to binding in the rear suspension.
Any thoughts or inputs would be awesome before I dive face first into this. Hoping to at least make it rideable this coming weekend, and then I will pour in whatever parts it needs to truly be in tip top shape asap.
Thanks in advance!
Thanks in advance!
