Hello
These days, I changed the oil on my motorcycle for the first time.
In the manual, it is indicated that the quantity is 2.2 liters (with oil filter change)
But after putting in the amount indicated by the manual, I realized that it was still below the level on the marker on the engine.
I ended up putting about 200ml more to reach the level.
I was curious to know if this is normal, it's my first bike.
Also (and may be related) I live in Brazil. Here, the Ninja 300 is reputed to cause a lot of problems with the crankshaft.
There is a lot of debate on the internet. I don't understand much about mechanics, but I believe that crankshaft problems can be linked to a lack of oil, correct?
As it is an international forum, I would like to know if Ninja 300 has the same fame around the world or just in Brazil.
Thank you
Thank you
