1 - 20 of 276 Posts
· Premium Member
The wonderful thing about lightweight bikes is how easy it is to throw them around. Members such as Peanut_EOD race lightweight bikes, and with enough practice+skill, you can even compete, and beat, larger supersport bikes in the twisties.
However, because the Ninja 300 is considered a beginners bike, and is a cheap solution to getting on 2 wheels, the stock tires that come from the factory are considered very bad if to be used as an aggressive tire.
This thread is to give you all the information you need to know about what tires are the best performing tires that fit on the Ninja 300 without any modification.
If you plan on hitting mountain twisties or taking your Ninja 300 to the track, you should consider the list of tires below. Tires are one of the most essential parts of your motorcycle, and the difference between good and bad tires could mean the difference between life and death. (Or a rashed motorcycle)
*Unsure if 120's fit on the front tire, and if they would have a negative effect. Stay tuned for clarification*
Front Performance Tires
Diablo Rosso II
110/70R17 ~$99
110/70ZR17 ~$108
Battlax S20
110/70ZR17 ~$108
Battlax BT-003
110/70ZR17 ~$103
Battlax BT-016 (Being Replaced by S20's)
110/70ZR17 ~$95
Rear Performance Tires
Diablo Rosso II
140/70ZR17 ~$120
150/60ZR17 ~$130
Battlax S20
150/60ZR17 ~$131
Battlax BT-003
140/70ZR17 ~$120
150/60ZR17 ~$131
150/60ZR17 ~$115
Companies Which Sell Tires Listed Above
RevZilla.com **
SportbikeTrackGear.com ← Contact [email protected] for possible better pricing!
Motorcycle-Superstore.com
BikeBandit.com
MotoSport.com
** = Cheapest Prices Found
Have a pair of tires you feel fits the needs of aggressive riding on the street and at the track? Post up your claim to have it added to the list above!
· Banned
How will putting the 150 rear tire affect performance
i have heard it will make it more difficult to lean you will have to
lean harder which is perfectly fine with me
esp if the straight line handling (ie freeway) is a little more stable
· Premium Member
Discussion Starter · #4 ·
Can we add in info about tire compounds, or are all of these track specific tires? I love me a good dual compound tire since I commute 1000s of miles a year.. But I like to have my fun to :D
None of these are track-specific. They are considered performance street tires. I will continue to research the tires and add more information. I will also look into good sport tires that fit these bikes, but have longer life that may not be as good, so people don't need to frantically figure out what tires to buy.
Any possibility of getting this thread stickified for now? I may end up just creating one large thread with links to various threads about modifications (brakes, tires, track fairings, suspension..etc) as a 1-stop user guide area.. but for now, this'll do.
Yes, the larger the tire, technically the more input you'd have to give for it to lean. Wheels are designed for a specific width tire, so technically, wider isn't always better for a specific bike. Someone like Peanut who has experience racing and going hard on these smaller tires could probably chime in and tell you how the feel is, but with my bigger bikes, I've ridden both 180 and 190 tires and can't say I really felt a whole lot of difference. Because the 300 is so simple to throw around anyways as it is, I personally don't think you'd notice any negative effects, but don't quote me on that.
I will say, I am pretty sure I'll be getting the Battlax S20's in the 110/150 combo before Spring hits. It's one of Bridgestone's newest tires, a very good street tire but also good for track days. Their BT-003 has a more extreme tread pattern on it that wouldn't fair as well in wet conditions.
Reactions: 300love
· Premium Member
Discussion Starter · #6 ·
How about wet riding tires as well? I ride year round and will be in the twisties this weekend.
Your right hand will be the deciding factor on the success of that. ;)
Smooth throttle and only brake when the bike is upright...etc will truly be the factors to successfully navigate in the wet.
A tire like the BT-003 will probably be out of the question for you. While people have used that tire in rain, there are few sipes in that tire to direct water away.
Also note - be sure to use the same brand front tire as the rear. The sipes are designed to work together to displace water.
I've ridden in torrential downpours (Not intentional) at highway speeds for 20+ minutes at a time. It sucks, and one false move will signify disaster. Don't chop the throttle, make sure everything is smooth, try to keep the bike as upright as you possibly can, and navigate your way to your destination.
· Track Whore
I have used a few different tires for racing and track days. A good tire for track days and daily riding is the Bridgestone BT-003RS in 110/140 combo. They are ok for racing, but when they go off they give little warning.
I liked the Pirelli Diablo Rosso II's for racing they are nice and sticky and give you plenty of warning before they go off. The ones I used were 110/140.
The tires I mainly race on are Pirelli Super Corsa SC2 in 120/150. These are DOT legal tires in race compounds. I love these for racing. I can push them as hard as I want and they take it and ask for more. They are very predictable when they start to go off. Since I race in the 250 Production class I have to use DOT legal tires.
When I add my 300 to my race stable it will be getting Pirelli slicks in 90/125 since it won't be racing in any Production classes.
I will sticky it if someone seconds your request :D
But really what it looks like we need is a tire section haha, there are so many tires of tires for different styles of riding.. I am not able to do that, Stew would have to, and not sure what is going on with him, he has been logging on but not posting or answering PMs
· Premium Member
Discussion Starter · #9 ·
So Peanut, I assume that 120's fit the front tire with no issues? Is there a certain setup you recommend? 110/140 .. 110/150 .. 120/150? Are they all legitimate combo choices?
· Track Whore
The 120's fit fine on the front and the 150's fit fine on the rear. They just leave a bit of tire on the edge unused. The reason we use them is for the race compound. As far as the difference between the 110/140 120/150 combos. The bike is so light there is really minimal sluggishness.
I personally like when the bike gets twitchy. I throw it around like I'm date raping it and I like the fatter tires just fine. I can't wait to try those skinny little slicks though. More reviews to come.
Never had an issue myself with a sport bike in the rain.. I do it all the time.. On my last bike I had Dunlop Q2 tires and I could corner like no other in the rain :D I actually surprised myself, didnt think a bike could handle like that in the rain, and I just pushed it a little more each corner..
I really have very little I can add to conversations like this one, including race suspension setups, fairings, etc. But I've been watching a learning thats for sure. Love reading this stuff!
Hey Peanut_EOD, or anyone else.
I run Pirelli on everything I drive. Is there a set for winter and a set for summer that you can recomend? I dont ride track due to no med ins but do ride the hills and street.
· Track Whore
I would go with the Diablo Rosso II. They are a nice sticky tire. I tried the Super Corsa's on the street for a few rides and I just couldn't get them up to temp.
· Track Whore
Don't know. I've never used the 60 aspect ratio tires. I'd imagine it would make the profile of the tire more rounded.
· Premium Member
Discussion Starter · #20 ·
Lol well I am sure that won't be a worry for me then. I won't take it past 110. I have never thought about it before but how much will the 60 or 70 affect the bike?
I don't even think the 300 will reach 110, so you have nothing to worry about.
I've heard good things about the Diablo Rosso II's, so I as well would recommend them if you're going with Pirelli.
Glad this thread is helping some of you guys.
1 - 20 of 276 Posts
