Does anyone know how to make adjustments to the following:
- Brake lever
- Clutch lever
- Gearshift lever
I am trying to adjust both the brake lever and clutch lever closer to the handlebars. Also, I want to try different positions for the gearshift and see what feels more comfortableadjustments how, what are you trying to do?
Is it in there? I'll have to go over it againAre they in the manual? Should have come with one if you bought it new?
your going to need adjustable levers for that, there are no adjustments to move them closer to the grips..I am trying to adjust both the brake lever and clutch lever closer to the handlebars. Also, I want to try different positions for the gearshift and see what feels more comfortable
Oh ok.your going to need adjustable levers for that, there are no adjustments to move them closer to the grips..
I have not looked at the shifter yet, typically there is just a jamb nut on the linkage rod..
Are you trying to riase/lower the shifer? Or are you trying to change your shift points??
The only time I have experienced that is when I was not shifting hard enough, it was always 100% my fault. Have you noticed if this is the case with you?
