1 - 20 of 23 Posts
· Premium Member
Ouch!! I'd pull the stator cover for sure
· Premium Member
If you're going to put it on the kickstand you going to lose a little bit of oil just put a drain pan under there for now if you have wheel stands and get the bike upright shouldn't have to worry about any kind of oil maybe a few drops
Definitely something is in there hitting the stator and or flywheel
Yeah yikes! If I was you, I would just drain the oil. If it looks normal, then you probably didn't cause much damage. But if it's got a bunch of shiny bits in it, there might be something more wrong. I would pull off the stator cover and the clutch cover just to see both sides, but yeah if the sound is on the left side, check the stator cover first. Mind the magnets when pulling the cover off.
· Premium Member
The stator cover needs to come off, and inspect the stator, flywheel, etc.. it almost sounds like one of the stator bolts has worked it's way loose, and is hitting the flywheel.
Either way it needs attention before you may cause serious damage, something isn't happy in there.
I'd drop the oil anyway, most likely you're going to want to do an oil and filter change after all is said and done.
· Premium Member
Good deal, I got to tell you to put a dab of loc-tite on the bolts, so it doesn't happen again.
Dumb question here: how did you remove the stator cover? I'm doing a replacement myself and can't seem to be able to remover the cover. I've removed the outer bolts and and it only comes out about half an inch then it gets stuck on something. Do I need to remove the center cap and remove that center bolt? Thanks in advance!
· Super Moderator
Have you removed the coolant pipe that goes from the radiator to the water pump?
You don't have to touch the 'center bolt', which is not a bolt but a cover that can be removed to access to the crank shaft to spin the engine for maintenance or repairs.
Yes I have removed the coolant pipes, I found out the hard way that the center bolt doesn't have to be messed with lol.. I tried loosening it like a moron. I think I need to remove the speed sensor bracket to work it loose..
· Super Moderator
Yes, you do need to remove the gear position sensor bracket. That comes out very easily though.
Then you should be able to pull it out. If your bike is low miles, you may be able to reuse the gasket. Pull it out gently. However, it's always a good idea to put a new gasket.
When you pull out the cover, some oil may come out too, and there are some 'dowel pins' too. Be careful not to lose them.
I will try it tonight. My bike has 14k so it's due for a new one. I have a new gasket also. I have a new stator cover from ebay because the previous owner jb welded the corner of the existing cover. He did allot of things wrong to this bike and I'm slowing bringing her back. What are these dowel pins you speak of?? And where are they located?? Thanks in advance bud.
· Super Moderator
Those are three or four pins that are used to align the cover with the engine body. Both the engine and the cover have some holes, three or four, I think. When assembling, y start by sliding the pins in the engine holes. Half of the pins bodies will stick out of the holes. Then you put the cover by matching the pins in the cover holes. That aligns the cover with the engine and it should make it easier to screw in the bolts.
Also, I'm almost sure there are at least two bolts that are longer than the others. Take note of the position when you take them out, Anyways, not a big deal if you don't, as you will quickly realize some of them are too long for some of the screws.
Thank you very much for the info. I finally finished putting her back together but now I've encountered another small issue. When I start up my Ninja she shuts off whenever I put her in gear, with the clutch engaged. Not sure if that has something to do with the shifter because I did take that off in order to remove the Stator cover. What's your take on this? Thanks in advance.
1 - 20 of 23 Posts
