1 - 2 of 2 Posts
Engine: Four-stroke, liquid-cooled, DOHC, parallel twin
Displacement: 296cc
Bore x stroke: 62.0 x 49.0mm
Compression ratio: 10.6:1
Cooling: Liquid
Fuel Injection: DFI® with dual 32mm throttle bodies
Ignition: TCBI with digital advance
Transmission: Six-speed
Final drive: Chain
Frame: Semi-double cradle, high-tensile steel
Wheelbase: 55.3 in.
Rake / trail: 27 degrees / 3.7 in.
Front suspension / wheel travel: 37mm hydraulic telescopic fork / 4.7 in.
Rear suspension / wheel travel: Uni-Trak® with 5-way adjustable preload / 5.2 in.
Front tire: 110/70-17
Rear tire: 140/70-17
Front brake: Single 290mm petal-type disc with two-piston hydraulic caliper
Rear brake: Single 220mm petal-type disc with two-piston hydraulic caliper
Overall length: 79.3 in.
Overall width: 28.1 in.
Overall height: 43.7 in.
Seat height: 30.9 in.
Curb weight: 379.3 lbs.
Fuel capacity: 4.5 gal.
Color choices / special edition: Pearl Stardust White, Lime Green / Ebony, Ebony
Warranty: 12 months
Optional Good Times™ Protection Plan 12, 24, 36 or 48 months
Source: Kawasaki USA
Discussion Starter #2
More detailed specifications from Kawasaki Canada below
ENGINE
Type:
4-stroke Parallel Twin
Displacement
: 296cc
Bore and Stroke: 62.0 x 49.0 mm
Cooling:
Liquid-cooled
Compression Ratio: 10.6:1
Valve System: DOHC, 8 valves
Fuel System: Fuel Injection: 32mm x 2 (Keihin)
Ignition: Digital
Lubrication: Forced Lubrication, wet sump
DRIVETRAIN
Transmission: 6-speed, return
Final Drive: Seeled chain
Primary Reduction Ratio: 3.087 (71/23)
Gear Ratio: 1st: 2.714 (38/14)
Gear Ratio: 2nd: 1.789 (34/19)
Gear Ratio: 3rd: 1.409 (31/22)
Gear Ratio: 4th: 1.160 (29/25)
Gear Ratio: 5th: 1.000 (27/27)
Gear Ratio: 6th: .857 (24/28)
Final Reduction Ratio: 3.000 (42/14)
Clutch: Wet multi-disc, manual
FRAME
Type: Tube diamond,steel
Wheel Travel: Front: 120mm
Tire: Front: 110/70-17 M/C 54S
Wheel Travel: Rear: 132mm
Tire: Rear: 140/70-17 M/C 66S
Caster (Rake): 27°
Trail: 93mm
Steering Angle (Left/Right): 35° / 35°
SUSPENSION
Suspension, Front: 37mm telescopic fork
Suspension, Rear: Bottom-Link Uni-Trak with gas charged shock and 5-way adjustable preload
BRAKES
Front: Type: Single 290 mm petal disc
Front: Calipers: Single balanced actuation dual-piston
Rear: Type: Single 220mm petal disc
Rear: Calipers: Dual-piston
DIMENSIONS
Overall Length: 2,015mm
Overall Width: 715mm
Overall Height: 1,110mm
Wheelbase: 1,405mm
Ground Clearance: 140mm
Seat Height: 785mm
Curb Mass**: 172kg
Fuel Capacity: 17 litres
PERFORMANCE
Maximum Power: 29.0 kW {39PS} / 11,000
Maximum Torque:
27.0 N·m {2.8 kgf·m} / 10,000 rpm
DETAILS
Warranty: 12 months warranty
ADDITIONAL COST OPTIONS
Good Times Protection Plan: Up to 48 months more
MSRP
Ebony: $5,799
EX300BDF
Ebony / Metallic Moondust Gray:
$5,999
EX300BDFA
1 - 2 of 2 Posts
