1 - 7 of 7 Posts
How old is the gas?
How long will it run after starting?
Problem just begin recently?
We need more info in order to help you.
Got your PM.
The aftermarket replacement ignition lock assy lacks a resistor that is required.
There is info here or on Ninjette about the resistor.
According to a knowledgeable member over at Ninjette, the ignition key may have a transponder in the key that needs to mate with the ignition and ECU.
In North America, the 2014 300 keys do not have a transponder. Which, I suppose makes sense given that the keycode is etched on the back of the triple tree.
Hmmm...guess that's not it then.
Back to square one...
SEARCH IN THE CURRENT
AND SHOW ME
jkv45
Veteran
Join: Jul 2018
about 12 hours ago
Re: 14 ninja 300
You should copy these messages and post them in your thread.
Others may have ideas as well.
Jay […]
jkv45
Veteran
Join: Jul 2018
about 12 hours ago
Re: 14 ninja 300
Check all the fuses as well as the battery voltage and grounds.
Do you have another battery you could try? For the lights and signals to go out wo […]
Welcome Committee
Junior Member
Join: Mar 2013
1 day ago
Welcome to Kawasaki Ninja 300 Forum
Thanks for registering at Kawasaki Ninja 300 Forum! We are glad you have chosen to be a part of our community and we hope you enjoy your stay.
Please […]
1 - 7 of 7 Posts
