Drive train lash anyone? - Page 4 - Kawasaki Ninja 300 Forum
 8Likes
post #31 of 48 (permalink) Old 10-10-2019, 09:12 PM Thread Starter
SparkyMJ's Avatar
I've been using standard Kawi and Honda conventional 10w-40 4 stroke oil. Nothing special. I used to use motul synthetic, and that was what my CCT didn't work well with. I do my oil changes absolutely no later than 3000 mile intervals. I am starting to get into higher mileage territory, and I like to keep on top of those things, especially using conventional oil. I also change the oil after any service on the motor, or track day.
I've been riding it some more, and the lash is the same so it seems since before the shimming, and I've been focusing on making sure my shifts are as "by the book" as possible, and it has been working okay recently. No clutch issues, no slippage. I fixed that when my previous one wore out, it had rainbow'd steels.
Also yes, when I did the clutch replacement I was aware of the types of wear that can form in the clutch. The basket had only polished areas where the tines on the friction plates would start to wear in, no actual wear. I couldn't feel the shiny spots with my fingers at all, So I left them as is. The clutch basket is on the crankshaft output right? or is there a gearing between the actual crankshaft and the clutch basket? I am wondering if there is any easy gears to inspect right behind the clutch basket.
Thanks guys.
-Mike
SparkyMJ is offline
post #32 of 48 (permalink) Old 10-10-2019, 09:19 PM
There is a set of gears between the crank and clutch.
post #33 of 48 (permalink) Old 10-11-2019, 10:10 AM
I would do some research about the Factory Pro Shift Kit for the Ninja 300 before disassembling the trans.
Not sure if it's going to solve all the issues, but it's supposed to stop it from popping out of gear and hitting false neutrals. Might cure the problem for you.
Also make sure the shift linkage is adjusted and lubed. Some people have reported that the linkage can hit parts of the rearsets and not move completely when shifting.
post #34 of 48 (permalink) Old 10-11-2019, 10:22 AM
I was looking at that kit. So far I've had no shifting issues but I dont like leaving well enough alone so maybe I'll get it
post #35 of 48 (permalink) Old 10-24-2019, 05:09 PM Thread Starter
SparkyMJ's Avatar
Kenny yeah you are right. The lash has slowly been worsening, so the least I can do is investigate the gear set between the clutch basket and the crank. Wouldn't be a terrible job to replace if that was the only issue, Id gladly do that over a transmission rebuild even if I have to split the crankcase, but hopefully I wouldn't.
Once I finish my brake job on my car, then I can afford to pull the bike apart. oil change is coming up soon here too, so not a bad time at all.
The lash has gotten so bad that when I am riding hard, and you come into a turn in the twisties and are trail braking, and then when you apex and start adding throttle in, the knock is almost unsettling, causes momentary unbalance and sketchy stuff. Almost feels like a tiny clutch kick right then, and it sucks. So Im going to really start looking into opening er up to get this at least addressed. The shifting has actually been going quite well lately, I have been sure to make very positive shift changes, and it has rewarded me with complete shifts every time.
Will update probably this weekend or early next week when I pull er apart.
-Mike
SparkyMJ is offline
post #36 of 48 (permalink) Old 10-24-2019, 09:26 PM
If it's something that is rapidly getting worse I'd signing asap. Small issues can become big ones if something let's go.
post #37 of 48 (permalink) Old 10-25-2019, 03:05 AM Thread Starter
SparkyMJ's Avatar
Hah! Finally a great lead. Based on general research, I strongly believe this is my entire issue. Video link attached.
So i opened up my clutch cover today for the hell of it, and I learned a few things.
-zero wear on the clutch gear and crankshaft gear. They look stellar.
-my friction plates and steels from my recent replacement also look perfect.
-fingers on the clutch basket and the slots on the clutch hub look extremely minimally worn.
-and of course, the basket moves a ton about its gear. There was an audible rattling when you jiggle the basket, and I can clearly see the gears weren't moving at all.
So I did some research and it appears just about every bike has "dampers" of some kind actually inside the clutch basket unit, which is one piece, because its riveted together. Not sure what types are common, but I can see that some bikes have rubber dampers, similar to the type in the cush drive in the rear wheel, and others, like the ninja, have springs instead of rubber pieces.
According to this DIY article on replacing these "non serviceable" dampers in your clutch basket, the "clutch basket *should not* move independently from the clutch gear".
https://www.diymotofix.com/blog/how-...r-less-than-30
I couldn't find a lot more solid information regarding how the dampers are supposed to be when they're new, but I am assuming that, much like the cush drive, these dampers of all kinds are only effective when there is no literal play in the system. As promised, heres the video of me handling the pieces on the bike before removal, and after pulling the basket.
https://youtu.be/508HPwDcJFE
As you can see in my video, there is gross play in the basket, and when I pulled it off, you can see the springs loosely sliding back and forth in their groves. I can spin the springs around along their axis in the groves very easily, the springs have clearly been permanently compressed.
It's really annoying that bike manufacturers' solution to this problem is a $300 clutch basket because 6 little springs wore out. It sucks, the basket is in great shape, the gear looks perfect, its otherwise a perfectly good basket ready to take on thousands of more miles. And just about every bike manufacturer sells an entire clutch basket as a unit, that you cannot disassemble. I haven't done any research on the topic, but that article mentioned replacing the dampers (springs in this case) with parts from aftermarket makes, but the way they are installed, you couldn't remove or install them without permanently deforming the metal on the clutch gear...
I may try to defeat the rivets to get inside it and see if I can make myself my own serviceable basket, by doing kind of what that article described.
I see other threads online about these springs being loose, but it seems almost every case that the rider only notices noise, not any performance issues or lash. It looks like people shim these, but looking at the design of the 300 clutch and the other bikes, I don't think shimming is a good idea, since retaining the shims would be hard.
All in all, I am pretty sure this is my issue. So I ordered:
-new clutch basket assy
-new center hub (damaged it in removal, I'm stupid)
-new nut and washer for the clutch hub, I had to cut it off, that thing was SEIZED on there. only 10 bucks for both, so why not.
Can I get any confirmation that you guys think this is indeed my issue? Out of all the steel gears inside my motor anywhere, I have seen zero visible wear on the teeth on any of them. Cam chain gears, all the gears behind the clutch basket like the oil pump and others all look as good as new. So based on that assumption, I am assuming my actual transmission gears are likely in pretty good shape as well. They are straight cut gears, and have a designed in amount of gear mesh to allow for proper shifting, and when I was handling the clutch hub and the countershaft after I got the clutch off, it spins the transmission very very smoothly in neutral, very little noise, no hitching or anything adverse whatsoever, so I would say it's in great shape. The clutch basket was the only thing I found that was blatantly messed up, and I was expecting to find something blatantly messed up to match with my blatant ridiculous lash, so to me that fit the description. It also makes sense that things like springs would gradually weaken/get squashed over time with use, so that fit the bill as well.
I need some feedback here, back me up if you think this was the right item to replace. It was a lot of cash, so if it was the wrong thing, I would certainly want to return my items...
Everything else looked as perfect as I could expect a bike with some mileage on it could look without taking the motor out.
Thoughts? Sorry for the long write up, I had a lot to share. Hopefully this could help some poor sap in the future with the same issue that I've got.
Thanks in advance fellas.
-Mike
SparkyMJ is offline
post #38 of 48 (permalink) Old 10-25-2019, 06:35 AM
This was actually one of the first things I mentioned. If there is play in those springs it can cause the issues you mentioned. The springs are in just about every motorcycle clutch setup and they do wear out over time. Can't guarantee it's your problem but it's definitely a problem.
Hopefully replacing this fixes your issue!
post #39 of 48 (permalink) Old 10-25-2019, 10:09 AM
Yes it was - back in post #8.(EDIT - actually you first mentioned it in post #6.)
You were more specific than I was in post #7, but we were both looking at the clutch basket assembly as a possible issue - but you nailed it.
Sure sounds like the problem to me.
post #40 of 48 (permalink) Old 10-25-2019, 10:37 AM
30 years turning wrenches have to be good for something
"Wobble" or vibration from drive train Dezagon Ninja 300 Issues and Troubleshooting 11 10-19-2015 10:25 AM
Ottawa Bus/Train Crash jeff Off-topic Discussion 3 09-19-2013 04:01 PM
Mulholland Drive Videos jeff California 13 04-29-2013 10:11 PM
hard drive magnet on oil drain plug to catch metal shavings cruizin Ninja 300 Appearance & Modifications 14 12-07-2012 12:33 PM
