Ninja 300 injectors not squirting - Kawasaki Ninja 300 Forum
  • 1 Post By Kennylxix
post #1 of 6 (permalink) Old 09-11-2019, 12:35 PM Thread Starter
After crashing my ninja 300 the fuel injectors aren’t pulsing anymore. They have a solid 12 volts to the hot wire but the ground one has no signal. The fuel pump works and the bike turns over and will start with starting fluid.
Accident damage was front end such as forks and radiator
Bryan12x is offline
post #2 of 6 (permalink) Old 09-11-2019, 12:41 PM
See if this thread has any helpful info - https://www.kawasakininja300.com/for...er-sensor.html
post #3 of 6 (permalink) Old 09-11-2019, 03:17 PM
The service manual unfortunately doesn't go into how the engine gets shut off when the vehicle down sensor is tripped but I suspect it shuts the fuel pump off. This would make sense as the main reason for the sensor is to stop fuel from being sprayed from a damaged hose.
That being said the manual does, in good detail, describe how to test the vehicle down sensor. It appears that, when working correctly, the sensor should reset itself when upright again. It's possible yours is pushed at an angle though.
Are you sure there gas in it? No offence but I'm a mechanic and have seen it quite a few times over the years
post #4 of 6 (permalink) Old 09-11-2019, 03:25 PM Thread Starter
Are you sure there gas in it? No offence but I'm a mechanic and have seen it quite a few times over the years[IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
yes I put fresh gas in the tank 😁
Bryan12x is offline
post #5 of 6 (permalink) Old 09-11-2019, 03:45 PM
Ok. Well I would imagine if the vehicle down sensor were tripped the fuel pump wouldn't run but I could be wrong. All you need is a multimeter to test it though. I'd do that first since it's easy to do then go from there.
post #6 of 6 (permalink) Old 09-11-2019, 05:39 PM Thread Starter
i checked the tip sensor it seems to be in working order and still in place.
Bryan12x is offline
Vacuum pipe on injectors was disconnected!! Unrealfarcry Ninja 300 General Discussion 0 11-21-2014 10:11 PM
It is *not* "not if, but when you crash" andrewm921 Crash Boom Bang 10 06-19-2014 03:41 PM
Has anyone synchronized the injectors/throttle body silver Ninja 300 Service and Maintenance 2 04-06-2014 08:08 PM
Front brake not as touchy and not as strong after installing ASV levers... sammy5001 Ninja 300 General Discussion 13 03-31-2013 05:33 PM
Fuel injectors. What cylinder is what? HateSneezing Ninja 300 Issues and Troubleshooting 6 03-02-2013 06:08 PM
