2013 Ninja 300 Not cranking - Kawasaki Ninja 300 Forum
 3Likes
post #1 of 23 (permalink) Old 09-04-2019, 02:55 PM Thread Starter
Hello everyone. I am new to posting on the forum but have read a lot of posts here. My question for you is my ninja 300 died on me after leaving a traffic light and got into 4th gear. I was not racing or driving like a maniac. But as I went into 4th it started stuttering and I put it into 5th and kept stuttering. By the time I put it back into 4th and gave it gas, she shut off. I immediately pulled in the clutch and just coasted to a safe side on the road. Now, since it will not crank. The fuel pump primes, it rolls in neutral, I know the kickstand switch and neutral switch works because the fuel pump will not prime with the kickstand down nor will it if I have it in gear without the clutch pulled in. I was made aware from other posts that the oil light will come on due to it not being on and not having pressure but I do not see any oil in the glass. I’ve switched batteries with my Gsxr-750 and the same thing. With my knowledge of vehicles it seems to be an electrical issue. I’ve checked the fuses under the seat as well. Please help. She has been sitting there for two months now and it sucks seeing it just sit there.
Groland97 is offline
post #2 of 23 (permalink) Old 09-04-2019, 03:20 PM
Originally Posted by Groland97 View Post
Hello everyone. I am new to posting on the forum but have read a lot of posts here. My question for you is my ninja 300 died on me after leaving a traffic light and got into 4th gear. I was not racing or driving like a maniac. But as I went into 4th it started stuttering and I put it into 5th and kept stuttering. By the time I put it back into 4th and gave it gas, she shut off. I immediately pulled in the clutch and just coasted to a safe side on the road. Now, since it will not crank. The fuel pump primes, it rolls in neutral, I know the kickstand switch and neutral switch works because the fuel pump will not prime with the kickstand down nor will it if I have it in gear without the clutch pulled in. I was made aware from other posts that the oil light will come on due to it not being on and not having pressure but I do not see any oil in the glass. Iíve switched batteries with my Gsxr-750 and the same thing. With my knowledge of vehicles it seems to be an electrical issue. Iíve checked the fuses under the seat as well. Please help. She has been sitting there for two months now and it sucks seeing it just sit there.
Do you think it ran out of oil?
Remove the inspection cover on the left engine case and see if you can spin the engine over manually with a socket and ratchet.
Re-check the fuses and battery connections, as well as the battery voltage.
post #3 of 23 (permalink) Old 09-04-2019, 03:55 PM Thread Starter
Re-check the fuses and battery connections, as well as the battery voltage.[/QUOTE]
Thank you for the response. I don’t think it did. I opened the oil cap and did not smell or see any smoke or burn. And don’t recall the oil light being on while it running.
I will do that this weekend. Will oil come from the inspection plate?
And also, do you think it could possibly be the stator?
post #4 of 23 (permalink) Old 09-04-2019, 05:37 PM
Thank you for the response. I donít think it did. I opened the oil cap and did not smell or see any smoke or burn. And donít recall the oil light being on while it running.
Check the oil with the cycle balanced level to see if it's excessively low.
No amount of oil will come out of the cover.
I don't think it's the stator.
post #5 of 23 (permalink) Old 09-04-2019, 06:01 PM
Stand the bike perfectly upright and you should see oil in the glass. If you don't see oil in the glass when the bike is standing straight up, then that's an issue.
Does the GSX-R start with either battery? If so, then it's not a bad battery.
One thought: have you checked the idle screw?
Rogue is online now
post #6 of 23 (permalink) Old 09-10-2019, 07:38 PM Thread Starter
So I got it back to my house and haven’t tried anything but now when I turn it on to crank it, the fuel pump primes and all the lights come on(neutral and oil light). When I hit the start button, it makes a really harsh static sounding noise until I let go of the starter button. All the lights and speedometer shut off. But when I let go off the starter, the fuel pump primes again and everything comes back on. Any idea? And yes. This batter has cranked my Gsxr many times recently
post #7 of 23 (permalink) Old 09-10-2019, 08:54 PM
This is one of three things.
Either your starter doesn't have enough power to turn the engine over indicating an issue with it or the electrical path to it, there is a problem with the gears between the starter and engine or the engine is locked up.
You can check to see if the engine is locked up by removing the large inspection plug on the left side of the engine (use a quarter with a pair of pliers in the giant flathead screwdriver slot) and use a socket to carefully and slowly turn the nut in there counter clockwise. It should turn fairly easy if it's turned slowly. You'll feel resistance as a cylinder comes up on compression which is normal. If the engine is locked it won't turn at all (do this in neutral). Also check your oil level in the sight glass on the right with the bike upright.
The other most likely culprit is a bad connection in the path from the starter relay to the starter or at the battery.
If any of this sounds intimidating you might want to take it to a shop.
post #8 of 23 (permalink) Old 09-11-2019, 12:06 AM Thread Starter
Thanks for the input. It doesn’t seem too intimidating as I am alittle mechanically inclines with vehicles. That’s a great idea with a quarter and pliers. I will test this and see if the engine turns. Hopefully it is not locked up as I just got this bike):
post #9 of 23 (permalink) Old 09-11-2019, 08:40 AM
No problem. Let me know how that goes and I can outline the next steps.
post #10 of 23 (permalink) Old 09-11-2019, 09:41 AM
I'd check the battery voltage as you are cranking before getting too carried away.
A fully charged battery reads 12.7V or slightly more. During cranking it should still read over 10V. It's possible the battery isn't fully charged or it's not as good as you think.
If the engine spins freely, I'd expect it to be an electrical connection issue if not the battery.
2013 zx6r swing arm and a 2013 ninja 300 swing arm. speedracerx Ninja 300 Appearance & Modifications 1 12-09-2017 03:57 AM
It is *not* "not if, but when you crash" andrewm921 Crash Boom Bang 10 06-19-2014 04:41 PM
2013 Ninja 300 > 2013 KTM Duke 690 Spanky Ninja 300 General Discussion 36 08-27-2013 12:24 PM
Front brake not as touchy and not as strong after installing ASV levers... sammy5001 Ninja 300 General Discussion 13 03-31-2013 06:33 PM
2013 Ninja 300 Review, Ninja 250 Review,Ninja 300 exhaust note, buying tips and run i WaSakiNin Kawasaki Ninja 300 Videos 0 10-01-2012 01:59 PM
