how to lift front tire to change brake pads? - Kawasaki Ninja 300 Forum
  • 1 Post By iahawk
post #1 of 4 (permalink) Old 08-17-2019, 02:04 AM Thread Starter
kpalaniuk's Avatar
Question how to lift front tire to change brake pads?
i'm a very new rider and sorry if this is in the wrong section but basically i just bought a 2013 ninja 300ex and got my back brake pads done and while doing that i bought spools for the back so i can do most the work myself in the future. my mechanic showed me step by step when he did my back brake pads...very nice. so should i buy spools for the front and then buy the roll lifters that uses the spools? will i be able to use one lift for the front and back (obv not at the same time) or is there a better way of going about lifting the front so i can change the brake pads..? i'm also going to be getting new front and rear tires in the next 2-3 weeks... any and all advice would help. This is my first bike, thanks
kpalaniuk is offline
post #2 of 4 (permalink) Old 08-17-2019, 08:40 AM
Just personally now ........... If it was I that was getting new tires, I would also have the shop do the front and rear brakes at the same time.
post #3 of 4 (permalink) Old 08-17-2019, 10:51 AM
OK, let's go through these questions....and welcome to the forum!...you don't need to lift your front end to change the brake pads. The front caliper is almost identical to the back one so the process of changing pads will be the same on both. There are plenty of youtube videos showing how to change brake pads.
As far as getting stands for your bike...you have a few choices. Putting spools on the back makes it easier to use a rear stand. For a front stand you don't use spools on our bike...the more common type of front stand lifts under the front forks. With ABS bikes the front stand still works but it's a little fussy to lift while still maintaining access to the front axle bolts. (due to the extra ABS parts on the right fork)
The other type of front stand lifts under the triple tree. These probably provide better access but are usually pricier.
The other type of stand is the kind that lifts the bike via the swingarm bushing holes in the frame. Google 'Abba superbike stand' for an example. this kind can lift both front and back wheels off the ground at the same time. Very cool but the most expensive option (of course).
As Pooba said, if you're not comfortable doing any of this you can take it to the dealer...but it is not difficult and is very satisfying to do your own work on your bike.
MAL likes this.
2014 Kawasaki Ninja 300 ABS
iahawk is offline
post #4 of 4 (permalink) Old 08-26-2019, 04:09 PM
also don't put the bike up only on a front stand. if you are doing front you also want to use a rear. I have used amazon/ebay venom stands with a lot of luck. Also the harbor freight rear stand is great
CleverRiver6 is offline
New brake pads & rotor color change zegzao Ninja 300 Service and Maintenance 11 09-03-2018 06:20 PM
This is what happens when you get too lazy to change your rear brake pads Timpo Ninja 300 Parts & Accessories 25 09-21-2016 03:25 PM
Worn out front brake pads, at 2800km!!! Chetztro Ninja 300 General Discussion 12 05-02-2016 02:50 AM
Breaking in my GSX-R shock, emulator, fork springs, and front brake pads.. warning Ninja 300 General Discussion 23 05-15-2014 11:43 PM
88 Fz front tire to replace ninja 300 front tire? Hotskull Ninja 300 Service and Maintenance 13 07-10-2013 01:38 AM
