Green liquid please help - Page 2 - Kawasaki Ninja 300 Forum
post #11 of 29 (permalink) Old 10-10-2016, 06:59 PM
Looks like some sort of grease. Idk where it would be from.
chevyguyjoe is offline
post #12 of 29 (permalink) Old 10-10-2016, 07:12 PM
dkw12002's Avatar
Yes, the 1st photo looks a little too green and thick, but the second photo looks much more like coolant and with the splatter pattern of the second photo, it looks too thin for grease.
dkw12002 is offline
post #13 of 29 (permalink) Old 10-10-2016, 09:50 PM
Topaz's Avatar
Maybe grease from the chain colored by coolant leaking from a hose?
Topaz is online now
post #14 of 29 (permalink) Old 10-11-2016, 02:17 PM Thread Starter
thanks for input guys so i took my bike to work when i got off about 4 hours later there was like 2 quarters worth of green liquid on floor so something is leaking and its coming from the kickstand side then when i parked my bike in the garage as soon as i got off i saw a drop hit the floor again from the kickstand area side when i look closer at the coolant resovoir tank its the same green thats in there can anyone isolate a more specific hose that i should check on the kickstand side?
hondagrom+300 is offline
post #15 of 29 (permalink) Old 10-11-2016, 04:03 PM
Topaz's Avatar
Take out the fairings on the clutch side, clean well all the hoses that you can see and let it drip. After some dripping, follow the wet green path and you will see which is the one leaking.
Topaz is online now
post #16 of 29 (permalink) Old 10-11-2016, 04:53 PM Thread Starter
dang so the fairing is off i cleaned off most of the green dried stuff and wow is this thing everywhere and it doesnt constantly drip either.. in maybe 2 hours time it went to a dime sizd puddle anyways if i dont end up finding where the source is would it be bad to ride the bike like this?
post #17 of 29 (permalink) Old 10-12-2016, 10:03 AM
Elijah's Avatar
Location: The Democratic People's Republic of Austin, Texas
On the plus side, with 2 quarts on the ground your radiator should be empty and the coolant reservoir should be dry making it easy to figure out if it's coolant.
If it is coolant, and you've leaked as much as your saying, then yes, it would be bad to ride the bike like that.
1) As the bike heats up the pressure in the cooling system increases. (Which is why you never take a radiator cap off a hot vehicle ... unless you're in to steam burns.) With a cool bike I'd check the coolant level in both the overflow bottle and in the radiator. Make sure the system is properly full. If it really leaked two quarts it should be pretty obvious it's not full.
2) Once you know the coolant level is correct, and the fairings are off so you can see the hoses going to/from the radiator, engine, coolant reservoir, etc., and you've made sure you've cleaned all the green mess up, start the bike.
3) Let the bike run and warming up. When the bike starts getting warm to hot and the cooling system is pressurized, inspect all the hose fittings going to/from the radiator, engine, etc. Look for either dripping or fluid bubbling/spitting out of the fittings. If it's leaking "two quarts" the leak should be easy to find. Also, watch the coolant level in the overflow reservoir and see if it's rising. The hose in the cap goes down by the kickstand to allow excess fluid to drip on the ground.
4) Anti-freeze also has a distinct, sickly-sweet smell when it's hot. I park my bike in the garage and in the morning I could smell an anti-freeze leak before I saw which one it was and I was only dripping a few drops. (And since it was a hose fitting the drops were inside the fairing and not on the ground. But, it was the smell that tipped me off to the leak.)
Give those things a go and see if you can eliminate anti-freeze from the list of possible suspects. (If all else fails change your anti-freeze to a different color and see if the weird green stuff changes color, it should if anti-freeze is part of the problem.)
Q. Why do I ride?
A. Because I've never seen anyone jogging and smiling.
2012 Ninja 650
2011 ZX6R
Elijah is offline
post #18 of 29 (permalink) Old 10-12-2016, 02:48 PM Thread Starter
hI thanks for giving me steps on what to do and maybe i typed it wrong but what i meant was 2 quarter sized puddles not 2 quarts. But when i started this thread the coolant level in the overflow tank was right above the letter L and now its sitting like on it so i think those dime sizd puddles are draining the resovoir tank slowly
post #19 of 29 (permalink) Old 10-12-2016, 09:36 PM
Elijah's Avatar
Hahaha, you said quarters and I saw quarts. Wow. Yeah, I remember when I had my first beer ...
Q. Why do I ride?
2012 Ninja 650
2011 ZX6R
Elijah is offline
post #20 of 29 (permalink) Old 10-14-2016, 04:48 PM
Jet Provost's Avatar
You were slimed!
Jet Provost is offline
2015 Liquid Graphite FZ-07 Myers_Balls Ex-300 Riders 6 10-29-2016 12:15 AM
Green is green???? stormsgate Ninja 300 General Discussion 4 04-26-2016 06:29 PM
The green from Indonesia dikun19 New Members Introduction 0 01-23-2015 03:41 AM
Anyone tried putting '13 SE green lower cowls on '14 all green 300? Red Hat Ninja 300 Appearance & Modifications 4 03-13-2014 11:08 AM
