Cheap eBay Rearsets Review. Very Good! - Page 2 - Kawasaki Ninja 300 Forum
post #11 of 26 (permalink) Old 04-02-2017, 05:22 PM Thread Starter
Karanx7's Avatar
Originally Posted by jrshooter View Post
i dont care what brand, cheap ebay or big name brand. take them apart and lock tite them all.
most dont even come put together, some are together but all are loose.
YES! If you complain that your bolts came out, then it's your fault for not putting loctite. These bikes vibrate, and bolts can loosen over time regardless of brand.
If you are using rear sets, you need to loctite the bolts!
2013 Ninja 300 - 2002 Acura TL - 2016 Corvette Z06
Karanx7 is offline
post #12 of 26 (permalink) Old 04-03-2017, 11:33 AM
Sure it is! Vehicles should come in a box and should be self assembled just to make sure everything loctited...
It's not a user's fault. It's a users responsibility. Whole different concepts. It simply isn't practical to assume that every motorcycle part has to be completely taken apart and reassembled before installation. Mechanics sure as hell don't.
- If someone's answer is useful, consider leaving a Like or a Thanks. The motivation to give a quality response is appreciated.
- Check out
- Thanks for reading! If you want to see some interesting How-To's and tips, check out
post #13 of 26 (permalink) Old 04-12-2017, 05:22 AM
Agreed, had it happen to me a couple of times on different bikes.
snowboarder1493 is offline
post #14 of 26 (permalink) Old 05-10-2017, 04:36 PM Thread Starter
Karanx7's Avatar
I find two things wrong with your logic. First, it's both the fault and the responsibility of the user, but the end result is really what matters. Secondly, the bolts that require loctite do come with it from the factory.
Aftermarket parts cannot be treated like factory replacements. It absolutely is your fault if you don't use loctite on rearsets, and a bolt falls off. You don't have to assume every parts need this, but rearsets do.
Rogue likes this.
Karanx7 is offline
post #15 of 26 (permalink) Old 05-11-2017, 03:03 AM
Tang's Avatar
Love the color combination of the bike!
I've got the same generic CNC aluminum rearsets, more or less, for about the same price. They haven't been trouble free but I've managed. I fixed the brake light issue with a longer spring and some fine-tuning. The biggest issue is that the main bolt which serves as the axis for the gear lever wasn't properly attached from the factory, and while riding at night at 90 mph or so, around 50 miles from home, I tried to switch gear and the lever wasn't there. Scary as hell while your in fast trafic and can't see anything since it's dark. The lever was dangling there hitting the floor hanging by the linkage, so thankfully I didn't lose it. The seller refused to take responsibility which sucked. I had to ride 50 miles in 6th gear at night in Florida traffic. Not fun. I actually didn't think I would make it but this bike is actually usable stuck in 6th gear. Who would have guessed. Moral of the story, use loctite.
I also had some clearance issues, so I had to move the shift lever out with some spacers and a longer bolt.
Besides that, I'm happy with it. The gear changes are super crisp and short. I can't stand OEM gear changes anymore thanks to it. Being able to adjust the position is also great.
I don't have any other picture at hand where the rearsets are visible, so this pic will have to do. I was trying out the new pizza bag I modded. There's a post for it if anyone's curious.
my i get the pic your phone holder , how to install it please? thank you
Leo Vince Gp Corsa Slipon , Zero Gravity Corsa windshield
Tang is offline
post #16 of 26 (permalink) Old 05-12-2017, 02:08 AM
Look up "Steering Bolt Ram Mount", and you'll see plenty of pics around the forum or Google. It's pretty typical. You have to drill and tap the steering stem bolt yourself and install a RAM mount threaded adapter. If you have a drill (preferably a column drill) and the right tap, it isn't that hard to do.
- Check out
post #17 of 26 (permalink) Old 05-12-2017, 09:23 PM
Javy's Avatar
i also installed cheap eBay rear sets only complain is that now the position is less comfortable (i also changed clip ons ) and when i ride with a pilon their boots crash into mines ,
Javy is offline
post #18 of 26 (permalink) Old 05-12-2017, 10:01 PM
Javy's Avatar
The full weight of the bike was on the foot peg as the bike slid across the track into the gravel. The foot peg took the damage without transferring it to the bike or the rear sets. I replaced the foot peg for like $10.
These are perfect quality rear sets for like a $100. You can't really beat them.
my brother low sided i has the same sliders it bends and break the md fairing too bad experience
Javy is offline
post #19 of 26 (permalink) Old 05-13-2017, 02:42 PM
Those are the same ones I have. They're adjustable so just play with them. I put them too high to begin with and my knees were not fitting into the tank cutout right, but since I moved them down and back a notch I love them and can't stand sloppy OEM gears anymore.
- Check out
post #20 of 26 (permalink) Old 05-06-2019, 02:45 PM
yipsama's Avatar
Looks like your ebay rearsets are installed in a good way.
I have bought these eaby rearsets as well, but I cannot figure out how the brake side should be installed.
Do you have pictures of the back on your brake side rearset? It's the brake system and brake light I don't know how to connet them with the rearset.
I am also trying to make a video of how to install these ebay rearsets. I would be really appreciate if you can show the right way to install them.
Thanks so much!
To be helpful!
yipsama is offline
eBay rearsets for $100? Or name brand? Suicide doors Ninja 300 General Discussion 18 07-10-2016 06:47 PM
Has anyone bought and installed ebay rearsets recently? Koreo Ninja 300 Parts & Accessories 5 06-11-2016 09:07 PM
eBay Chinese rearsets MirinNinja Ninja 300 Parts & Accessories 3 01-08-2015 09:18 PM
Cheap eBay parts Wilhelm_ryan Ninja 300 General Discussion 44 03-06-2013 09:02 PM
Cheap accessories from ebay SpicyNuggets Ninja 300 Parts & Accessories 24 02-04-2013 02:49 AM
