Weak rear brake - Kawasaki Ninja 300 Forum
post #1 of 11 (permalink) Old 03-21-2014, 11:41 AM Thread Starter
rockieb's Avatar
Weak rear brake
So I just got my Vortex rearsets and had them installed yesterday. Everything came out excellent except now my rearbreak barely even works and I don't have a rearbreak light actuator. The switch is fine, I don't really need it as long as my breaks actually do work...which it doesn't.
But what I'm trying to say is, I've hooked up everything correctly and now my break barely works. I'll press down on the pedal and I just feel a weak spring and no break. So it's really sketch when riding fast.
Does anyone know how to adjust my breaks or make sure they'll work right? Thanks
And for all you who have Vortex rearsets, which position do you have them on?
(Can anyone also tell me what's the max distance the peg can go back?)
rockieb is offline
post #2 of 11 (permalink) Old 03-21-2014, 05:19 PM
DaveTheCanuck's Avatar
Did you install them yourself or have a shop do it?
The Vortex rearsets require reversing the position of the rear master cylinder, which requires disconnecting the rear brake line.
There's probably air in the system. If you did it yourself, bleed the rear brake. If a shop did the install, get them to do it.
2013 Kawasaki Ninja 300 - Track bike
2011 Yamaha XJ6N - Daily driver
DaveTheCanuck is offline
post #3 of 11 (permalink) Old 03-21-2014, 07:05 PM
cruizin's Avatar
also if you drop in some decent DOT 4 brake fluid when bleeding the lines you will find it way better then the stock crap Kwaka shove in there when you first get the bike the stock crap makes the brakes feel like a sponge
cruizin is offline
post #4 of 11 (permalink) Old 03-22-2014, 01:06 AM Thread Starter
rockieb's Avatar
Thank you for the replies but could someone show me how to bleed my rear break?
rockieb is offline
post #5 of 11 (permalink) Old 03-22-2014, 01:10 AM
cruizin's Avatar
this is something you had better get right from word go , your life is on the line with brakes. honestly if you donít know what your doing your better off seeing a mechanic
cruizin is offline
post #6 of 11 (permalink) Old 03-22-2014, 02:19 AM
Post Whore
http://faq.ninja250.org/wiki/How_do_...brake_lines%3F
It wasn't that hard to learn how to do. You'll know it's right when the brake feels firm. If you have the tools, give it a go. The rear brake isn't that essential anyway; I went without a functional rear brake for a few weeks lol.
tfkrocks is offline
post #7 of 11 (permalink) Old 03-22-2014, 03:09 AM
Atticus27's Avatar
Rockie, I'm looking into getting some ATE DOT4 off amazon because I want to change my front/rear brake fluid.
Basically for rear brake, you can do what Cruizin does with a syringe and attach a thin rubber tubing to the syringe to the nipple, manually pull the syringe back vacuuming the rear brake fluid, add new fluid and repeat until you feel the old fluid is out. OR...go to harbor freight, get a $5 brake bleeder http://www.harborfreight.com/one-man...kit-37201.html which works just as well. We can do it together if you like because I want to do it too.
I know how to adjust so the rear brake light becomes more sensitive to turn on but i don't think that's what you're looking for...
Instagram: aphan_N3
Mods: ASV shorty levers, woodcraft slider spools, techspec tank grip, Plastidipped windshield and passenger rear pegs, delete front reflector, red LED brake light + modulator, Shogun no-cut frame sliders, Diablo Rosso II tire, SSR preload adjusters, Driven clip-ons, fender eliminator kit
Gears: Shoei Qwest (clear&darksmoke) / SP-2 Alpinestars Glove / Alpinestars GP Pro Jacket / Alpinestars Leather Track pants / Cortech Latigo Boots
Atticus27 is offline
post #8 of 11 (permalink) Old 03-22-2014, 05:31 AM Thread Starter
rockieb's Avatar
I'm down. Just give me a date and a time and I'll see if I can make it. And send me a list of what to buy
rockieb is offline
post #9 of 11 (permalink) Old 03-22-2014, 05:35 AM
cruizin's Avatar
location detail filling in working at its finest here. i urge you both to exercise some caution when doing your brakes, i hate to read about either of you injuring yourself cos you didn’t do the job correctly in the first place.
cruizin is offline
post #10 of 11 (permalink) Old 03-22-2014, 06:04 AM
Atticus27's Avatar
Originally Posted by cruizin View Post
location detail filling in working at its finest here. i urge you both to exercise some caution when doing your brakes, i hate to read about either of you injuring yourself cos you didnít do the job correctly in the first place.
Thank you for your concern It's something I've been waiting to do, i'll keep you updated on our endeavor. I've been doing a lot of research on bleeding brakes too, excited!
Instagram: aphan_N3
Hard break in, the only break in NoRvrs Ninja 300 General Discussion 10 08-27-2016 10:14 AM
Break-in. zimzim Ninja 300 General Discussion 90 12-03-2015 01:17 PM
FS: Some cracked fairings, OEM: front break lever, rear break pedal, handle bar grip quitit Parts and Gear for sale 7 01-11-2014 02:43 AM
Break In? Perkowski New Rider Section 4 11-19-2013 07:32 PM
weak handlebars Fox Ninja 300 Issues and Troubleshooting 14 04-22-2013 02:09 PM
