Chain ‘whooshing’ noise while riding! please help! - Kawasaki Ninja 300 Forum
  • 1 Post By Granpooba
post #1 of 9 (permalink) Old 07-01-2019, 08:49 PM Thread Starter
Basically, when i bought the bike it made this weird chain whooshing noise. The faster i ride the faster the noise gets. Tightening and lubing the chain does not fix the problem. Ive made sure its not too tight or too lose. Any suggestions? Any suggestions? Ill supply a link with a video of what im talking about. I let the clutch out in 4th gear on a stand. Any help would be greatly appreciated!! Thanks
https://youtu.be/NUpdcbbi6sE
NinjaJoel300 is offline
post #2 of 9 (permalink) Old 07-02-2019, 09:20 AM
Personal Opinion To me the chain appears to be loose and his hitting guards near " primary gear ".
Could be wrong though and other opinions would be appreciated.
post #3 of 9 (permalink) Old 07-02-2019, 11:54 AM
Have you checked the chain and sprockets for wear?
It may also have a link that is damaged or the slack may change significantly due to uneven wear of the sprockets.
post #4 of 9 (permalink) Old 07-02-2019, 08:34 PM
Just got done reviewing the video again, a few times. And I still think the chain is way do loose and does appear to be slapping the top of the swing arm.
But I could be wrong
I thought that I was wrong one other time, but I was mistaken.
post #5 of 9 (permalink) Old 07-04-2019, 01:14 AM
containment's Avatar
Kind of looks like a seized chain link(s) with all the jerking going on. May be that the sprockets are misaligned?
What'sa happenin' with your bike? Time for containment...
containment is offline
post #6 of 9 (permalink) Old 07-04-2019, 08:02 AM
Starting to sound like more than one issue here.
Could be multiple problems, with chain, sprockets, alignment, tension, etc.
post #7 of 9 (permalink) Old 07-10-2019, 07:29 PM
Did it get fixed yet? I am having same problem after installing new chain its making this same sound and sprockets are not wore out yet, seems sound is from front sprocket
Sohail is offline
post #8 of 9 (permalink) Old 07-10-2019, 08:54 PM
New chain on worn sprockets usually doesn't work well - even if the sprockets are not worn out. They are still worn, and don't make correct contact.
post #9 of 9 (permalink) Old 07-12-2019, 08:45 AM
Time for a .............................. " BELT DRIVE " .................................
New battery- won’t start. Blinker noise. Aaron Camacho Ninja 300 Issues and Troubleshooting 5 03-29-2019 03:03 PM
Aftermarket exhaust that doesn’t sounds soo growly and poppy TB300 Ninja 300 Parts & Accessories 5 03-24-2019 07:25 PM
Have you ever had a chain break while riding? Gables_Ninja Ninja 300 General Discussion 11 05-21-2018 11:59 AM
Won’t rev up RareTyler Ninja 300 Issues and Troubleshooting 12 05-14-2018 10:26 AM
Whistling-sound while riding. Help please! setujaq Ninja 300 General Discussion 16 11-05-2013 03:41 PM
