ABS light stay on after front sprocket change - Kawasaki Ninja 300 Forum
 7Likes
post #1 of 14 (permalink) Old 06-10-2019, 02:50 PM Thread Starter
Unhappy ABS light stay on after front sprocket change
hey guysssss,
Recently I change my ninja300 2014 front sprocket after 20000km, I ride about 30 minutes without speed sensor( I mean I have not speed numbers on my dashboard) , but now after change my front sprocket and fix the speed sensor my abs doesn't work, I unpluged battery, cleaned abs sensors, but ABS light is still on
I'm in country that there is no any kawasaki dealership and I should fix it alone
I think ecu saved this error but I dont know how to erase this fault
please help me guys
m3hi is offline
post #2 of 14 (permalink) Old 06-11-2019, 10:49 AM
IronWarrior's Avatar
On the N300 the ABS is completely separate from the ECU. This is important to note because the Speed Sensor (for the "numbers on the dashboard") has nothing to do with the ABS, and the Wheel Rotation Sensors, Front and Rear, for the ABS have nothing to do with the ECU/Speedometer. With this in mind, any work to the front sprocket should not cause an ABS error as the two systems are completely detached from one another.
Did you carry out any other maintenance? For example, while working of the front sprocket, did you do anything to the rear wheel? Anything happen to either wheel while riding? What is the condition of both sensor rings (the slotted disks on the rims)?
Thanks!
2012 Honda NC700SA
2015 Kawasaki Ninja 300
IronWarrior is offline
The Following User Says Thank You to IronWarrior For This Useful Post:
m3hi (06-11-2019)
post #3 of 14 (permalink) Old 06-11-2019, 11:19 AM Thread Starter
Thanks!
thanks for answer <3
I changed the tire,rear sprocket and chain before that and my ABS worked well, I dont know if its related but I changed 140/70-17 with pierlli 150/60-17 but as I said there wasn't problem with ABS
both sensors are clean and slotted disk on the rims are clean and are in good condition without any damage
I can take the pictures if it will help
I can't ride my bike beacause I fear to ride without ABS
m3hi is offline
post #4 of 14 (permalink) Old 06-13-2019, 09:58 AM
Tire change shouldn't have made enough difference to trip an error, it's only a 2.5% difference in outer diameter between the two sizes. Pictures of the two sensors/rings might help.
2012 Honda NC700SA
post #5 of 14 (permalink) Old 06-13-2019, 02:51 PM
Trace the wire and make sure it is in good condition and connected securely.
If that's good I would disconnect the battery and wait a few minutes before reconnecting it. It's possible that may reset the system.
IronWarrior likes this.
post #6 of 14 (permalink) Old 06-14-2019, 08:01 AM
Why do you fear to ride the bike without ABS You still have normal braking, do you not
IronWarrior and MAL like this.
post #7 of 14 (permalink) Old 06-14-2019, 08:22 AM
MAL
That sounds about right.
There's no need to "fear" not having ABS, just be aware of it.
There's probably more 300s sold worldwide without ABS than with.
And I don't think I ever actually 'engaged' it yet (except for testing purposes, to see what it feels like).
MAL is offline
post #8 of 14 (permalink) Old 06-14-2019, 10:59 AM
As a point of Reference, my Honda has ABS, my Ninja does not. I have no concerns with having no ABS. I have had the ABS engage once on the Honda (without specifically trying to engage it) and in that situation I would have been fine without ABS (straight line braking, gravel road, one or two pulses before complete stop).
2012 Honda NC700SA
post #9 of 14 (permalink) Old 06-14-2019, 01:44 PM
Rookie28's Avatar
Check that your battery terminals arenít loose. Also make sure your battery is still in good condition.
Sent from my iPhone using Tapatalk
Rookie28 is online now
post #10 of 14 (permalink) Old 06-15-2019, 02:36 PM Thread Starter
Guyssss, I found that there is ABS self diagnosis on N300 and my problem is ( 45 in picture) rear wheel rotation senor (wire shorted or opened) and I should check where is the problem with the wire, thank u all for helping me
File Type: png Screenshot_20190612-161122_1560623636732.png (534.1 KB, 20 views)
m3hi is offline
abs
ABS light after tyre change. no_experience...big_ego Ninja 300 Issues and Troubleshooting 12 01-17-2019 07:33 AM
15 tooth front sprocket, speedometer change? guydude Ninja 300 General Discussion 7 12-28-2017 12:14 AM
After Market Fairing Stay? n_hutter Ninja 300 Parts & Accessories 8 02-09-2017 02:47 PM
WTB: front fairing stay, speedo, headlight assembly ninjarider189 Want to Buy 6 09-21-2016 09:37 AM
ABS and sprocket change Issues Ninjatenza Ninja 300 Appearance & Modifications 2 05-13-2015 10:59 PM
