Cut-out Problem - Kawasaki Ninja 300 Forum
post #1 of 3 (permalink) Old 06-09-2019, 07:55 AM Thread Starter
Unhappy Cut-out Problem
Hi everyone, so I've read through some threads of what I thought could be closely related problems, however I feel the need to post my own thread.
The background story:
I am a beginner rider. I bought a used 2015 Ninja 300 30th Anniversary Edition with 19000 km on the clock. The previous owner told me the bike wasn't used much in the last 2 years. Looking at the service history it had only been running 2000 km in the last 2 years since its previous service. I took a knowledgeable friend with me to look at the bike before I bought it. All was well, it ran all okay. Worth mentioning, when we were there, taking a look, it started without a problem. I took it home and started it a couple of times without actually driving it, as I haven't had my drivers or learners license then. Eventually it didn't start anymore. I figured it was because the battery hasn't been properly charged. I removed it, charged it, put it back, and all was well.
The problem:
Here I am, a month later, I have only ridden 2 weeks in total and I am experiencing cut-outs. I initially thought it was just me driving wrong, but now I'm thinking it's a fueling problem.
What happens:
I tested it in the following 2 ways:
1) I approach a stop on speed, brake, pull the clutch, brake, gear down from eg. 4 to 2, brake if needed, release the clutch when I think my speed matches. Sometimes it cuts out when releasing clutch, sometimes it cuts out while gearing down.
2) I approach a stop on speed, brake, pull the clutch, gear one down, use throttle to lift revs, proceed in gear, gear down again, use throttle to match revs, break throttle, stop. Worth mentioning, if I don't blip on each downshift the bike will also sometimes cut out.
Note with 1 I was shifting down multiple gears, keeping the clutch in and eventually releasing as with 2 I was downshifting gear to gear, rev matching.
Also, sometimes if I blip on idle at a traffic light, the bike also cuts out.
This being said, I have experienced times when it doesn't cut out. I will ride more and see if I can figure out more of a pattern.
My thoughts were that the bike is maybe idling too low, or a faulty fuel line or filter, but I think with the latter it would be more of a shuddering cut-out. It just simply dies. Maybe a faulty stand switch.
Like I said, I am very new to the motorcycling community, and thus also with bike maintenance and troubleshooting. Any proactive advice and help would greatly be appreciated.
Taro Lombard is offline
post #2 of 3 (permalink) Old 06-09-2019, 08:02 PM
If it had any gas in it when you got it, I'd start by completely draining the tank and refilling with fresh 87 octane. No ethanol is best, IMO, if you can get it.
I'd add 1oz per gal of Chevron Techron Concentrate Complete Fuel System Cleaner to the tank.
Also check that your air filter is in good condition. Bump the hot idle speed up to about 1500 temporarily, just to help keep it running, for the sake of safety.
I'd give that a try before taking stuff apart.
post #3 of 3 (permalink) Old 06-10-2019, 06:05 AM
diaslemuel's Avatar
QUestion that may help
What is the idle speed
When was the last time you cleant the throttle body
When was the last time the air filter was cleant
When was teh last time you adjusted the clutch
How many kms did the bike run
T&R,
Lemuel Dias
diaslemuel is offline
cut-out, cutout, dies, fuel, fueling
Ninja 300 engine cut-out in middle of intersection! Sid_for_speed Ninja 300 General Discussion 8 10-12-2014 10:43 PM
Shogun No-Cut Frame-Sliders sunjiaming2004 Ninja 300 Parts & Accessories 58 06-24-2014 12:13 AM
Headlight Problem: Bulbs Burning-Out CRNinja Ninja 300 General Discussion 6 11-18-2013 07:14 PM
No Cut Frame Sliders bundy Ninja 300 Appearance & Modifications 23 05-06-2013 10:15 PM
R&G Aero Frame Sliders (No cut!) Truesday Ninja 300 Parts & Accessories 15 01-06-2013 02:36 PM
