Problems with regulator / stator - Kawasaki Ninja 300 Forum
post #1 of 7 (permalink) Old 05-09-2019, 01:33 AM Thread Starter
Hey guys, i have a problem with my motorcycle (Ninja 300 SE - 2013), i have about 24k on it. When i'm riding in traffic, i see the battery warning light, that's only happening in traffic, not on the highway, i tried with two batteries and i got the same result. I tested my battery with a multimeter, that's the result 12.50 (normal) - 12.36 (open x1) - 10.57 / 12.88 / 13.56 / 14.05 (open x2), totally normal, that's the result for the morning. Both batteries are fine, that's a problem with the regulator / stator. After staying in trafic, the battery just don't charge, they stuck at 12.03 / 12.34. It's weird but i'm not sure if the problem is from the regulator or the stator, anyone already got this problem?
Thanks!
Sorry for my bad grammar, i'm french canadian.
Dekicou
Dekicou is offline
post #2 of 7 (permalink) Old 05-09-2019, 10:34 AM
Thanks!
I would say that you definitely have a charging problem. Depending on the motorcycle manufacturer, all battery charging systems are designed to charge above a set RPM. Not all bikes are the same, but it definitely sounds like yours is not charging at the proper RPM.
Sorry, I can not give you a definite answer. But what I can say is that their is nothing wrong with your French Canadian grammar. My Daughter In Law, is French Canadian and can not speak a word of English.
post #3 of 7 (permalink) Old 05-09-2019, 12:23 PM
diaslemuel's Avatar
I see that the voltage is 13.98 which shows that there is charge being produced by the stator. Get the battery tested that is definately gone.
If the charger/stator was dead your bike would die completely and voltage would be 0
T&R,
Lemuel Dias
diaslemuel is offline
post #4 of 7 (permalink) Old 05-09-2019, 02:58 PM
I myself usually go with the bad battery. But unless I am wrong in the reading, he has stated that he has tried ( 2 ) batteries.
post #5 of 7 (permalink) Old 05-09-2019, 09:47 PM Thread Starter
I tested with the oem battery and the new battery is a Yuasa YTX9-BS 12V, fuses are fine too
Dekicou is offline
post #6 of 7 (permalink) Old 05-09-2019, 09:49 PM Thread Starter
[QUOTE=diaslemuel;1709114] This is not normal..? That's what i got when the bike charging, but after a ride in the traffic, staying at 12V.
Dekicou
Dekicou is offline
post #7 of 7 (permalink) Old 05-19-2019, 10:56 AM
diaslemuel's Avatar
I would suggest connect wires to the multimeter and take a test ride and record or monitor to see voltage when bike stalls.
It can even be a simple open wire or loose ground.
T&R,
Lemuel Dias
regulator
ISO Stator Raver Parts and Gear for sale 2 10-26-2016 09:29 PM
WTB Stator for my Ninja 300 afrokenz Parts and Gear for sale 0 06-23-2016 11:56 AM
WTB: Stator Sadprice410 Ninja 300 Parts & Accessories 0 10-13-2015 11:25 PM
Stator Dimensions / photos cruizin Ninja 300 Appearance & Modifications 1 10-07-2013 06:35 AM
Stator output??? old3 Ninja 300 General Discussion 0 11-10-2012 12:59 PM
