No power to 2014 Ninja 300 SE - Kawasaki Ninja 300 Forum
 3Likes
post #1 of 18 (permalink) Old 04-22-2019, 08:52 PM Thread Starter
Hey guys.
Got my bike back in 2015, have had it for 4 years now, and the fourth time taking it out of winterization (I live in toronto).
I've had no problems restarting my bike in previous years. This year is different...
Grabbed my charged battery, and hooked it up like normal. I turn the key to on and it turns on normally (not starting the bike), and about 2 seconds after the initial dash lightup, it turns off. I quickly turned the key to off and the bike flickered the neutral light for about 3 or 4 seconds before completely dying. Now there is zero power to my bike. I have rechecked that there is good contact for terminals, have checked all of the fuses visually (including the main). Bike still has zero power and am not sure what to do. (battery is fully charged)
Thanks
Daveed is offline
post #2 of 18 (permalink) Old 04-23-2019, 08:05 AM
Rttoys's Avatar
Originally Posted by Daveed View Post
Hey guys.
Thanks
A battery can be ďfully chargedĒ but still be bad. Grab a volt meter (everyone should have one even if itís a cheapo from harbor freight) and connect it to the battery to see if you have 12v or near 12v. Turn the key on and see what the voltage does. If it drops, under 10v, you need a new battery. It should only drop a little, like a half volt or so, but a quick hit of the starter will put it under a load and youíll see the voltage drop big time. It should never get under 9v as a rule of thumb, but to be honest, anything under 10.5-11v is suspect.
Seems how you never said you replaced the battery, Iíll assume itís the original 4 years old one. I would replace it, no matter what. Cheap insurance.
Track-
'13 Kawasaki Ninja 300SE - Yoshi full exhaust, PCV, Vortex rear sets, gp shift, Dunlop Q3+ (formerly Bridgestone Battlax S20 EVO), GSXR rear shock, Barnett clutch and springs, Woodcraft clip-ons, Hotbodies race plastics, Ducati steering dampener, fully safety wired, racetech ft springs and gold valve emulators, ft stainless steel brake line, EBC HH pads, more to come.
'99 Ducati 996s
Street-
Ď18 Honda Grom
'14 Yamaha TW200
'07 Yamaha FZ1
CMRA #982
Rttoys is offline
post #3 of 18 (permalink) Old 04-23-2019, 09:07 AM
My money is on the " BAD BATTERY "
post #4 of 18 (permalink) Old 04-23-2019, 09:26 AM
I'm gonna say the battery is toast as well.
A volt meter and the tests that Rttoys mentioned will tell you.
post #5 of 18 (permalink) Old 04-23-2019, 09:34 AM
To be a little more specific with battery voltage...a fully charged 12v battery should be around 12.7 volts. If it only reads 12 volts it's no good.
I tried to cut and past this chart but was not able to...
12.7 volts = 100% charged
12.45 = 75%
12.24 = 50%
12.06 = 25%
2014 Kawasaki Ninja 300 ABS
iahawk is online now
post #6 of 18 (permalink) Old 04-23-2019, 11:52 AM
Yup, first step is to rule out a dead (but charged) battery. You might wanna check out this on how to test a motorcycle battery when the voltage is good but the engine won't start.
- If someone's answer is useful, consider leaving a Like or a Thanks. The motivation to give a quality response is appreciated.
- Check out
- Thanks for reading! If you want to see some interesting How-To's and tips, check out
post #7 of 18 (permalink) Old 04-23-2019, 03:29 PM Thread Starter
Odd. Always made sure i charged my battery over the winter. Battery reads 12.65 right now and will hook up like you said and see what happens. I can also attatch my brothers battery, ( ninja 300 too) and see what happens. Will update soon.
Daveed is offline
post #8 of 18 (permalink) Old 04-23-2019, 05:42 PM
12.45 = 75%
12.24 = 50%
12.06 = 25%
Can show me all the charged battery voltages that are out there in print. But to me, they mean absolutely NOTHING.
A battery can still show a fully charged voltage and still be bad.
What does matter is AMPERAGE and CAPCITANCE .
post #9 of 18 (permalink) Old 04-23-2019, 08:07 PM
Sure, itís not the be all, end all...but measuring voltage is a good place to start. Measuring high doesnít guarantee a good battery...but measuring low does guarantee a bad battery. Gotta start somewhere!
post #10 of 18 (permalink) Old 04-23-2019, 08:25 PM
PERSONALLY I would start at the parts store, with a NEW battery.
2014 Ninja 300, stalls sounds funny,no power bboycloudd Ninja 300 Issues and Troubleshooting 9 11-07-2016 09:20 PM
WTB 2013/2014 Ninja 300 SE/non-SE ABS/non-ABS (Buffalo-Rochester area, NY) CyberBrain Want to Buy 2 04-11-2015 08:35 AM
SE decal or no SE decal? doc_k Ninja 300 Appearance & Modifications 8 02-06-2015 10:11 PM
Power Commander, but no extra power? Michael V Ninja 300 Issues and Troubleshooting 14 08-10-2014 09:04 PM
No heat = no power skinnyinto Ninja 300 General Discussion 13 04-23-2013 01:06 PM
