Smog Delete Write Up - Kawasaki Ninja 300 Forum
post #1 of 19 (permalink) Old 10-18-2014, 10:23 AM Thread Starter
Well for the first time working on the bike, I must say it isn’t that bad. The fairings were easy to figure out without any instructions and everything else you can literally see everything you need to remove to access the area you want. So for my first Mod that I am installing on my Bike is the SSR Smog Block off Plate. If I knew it was only going to be a small piece of metal I probably would have just made it at work for much cheaper, but for 15$ it’s not that bad. While most of the pictures you will notice I have more taken off the bike, that’s because I am also installing a K&N pod filters.
links to products I used:
http://www.slingshotracing.net/catal...ate-p-498.html
http://www.oreillyauto.com/site/c/de...&keyword=02253
Any 1/2 inch plugs will work just i didnt know what size so i got the assortment to cover all grounds. But 1/2 inch is the correct size and you will need 2 for the valve
First step is to make her naked don’t need to go as far as I did since I was also removing the intake and all that I removed a lot of extras. You can see my lowers dangling, that’s because whoever installed my exhaust striped out that bolt and it’s just a circle. No need to drill it out just yet
I would say Sides, Fronts; Gas tank (not needed just makes it easier).
Next would be to remove the 2 tubes off the Valve and off the engine plate and air box.
Remove the 2 bolts on the engine plate
mattmid is offline
The Following 2 Users Say Thank You to mattmid For This Useful Post:
Hijinks (10-18-2014), Michael V (10-18-2014)
post #2 of 19 (permalink) Old 10-18-2014, 10:25 AM Thread Starter
Reinstall SSR Block Off Plate with 2 washers (Not Included)
Plug the inlet and outlet of the valve
This image is showing you the valve is easy to pull of the connection on the bike. Just slides off makes it easier to maneuver around to replug it
mattmid is offline
The Following User Says Thank You to mattmid For This Useful Post:
post #3 of 19 (permalink) Old 10-18-2014, 10:28 AM Thread Starter
I’m not pulling the 2 sensors, small hose running to throttle body or the valve itself like on the 250s as it’s a Air Pressure sensor it needs to stay installed.
Plug the Intake inlet, Im not showing this as I removed my intake completely.
But thats for a separate write up on Pod Install
Bam your done, Start her up
Should remove all backfiring found with Aftermarket Exhaust systems
mattmid is offline
FadedAxle (10-19-2014), Hijinks (10-18-2014)
post #4 of 19 (permalink) Old 10-18-2014, 09:16 PM
Sharmo's Avatar
What size caps did you use to block off the whole system?Specifically, whats the internal diameter of the caps?
Sharmo is offline
post #5 of 19 (permalink) Old 10-18-2014, 10:08 PM
Hijinks's Avatar
cant wait to do this. The backfiring kind of drives me crazy
Hijinks is offline
post #6 of 19 (permalink) Old 10-18-2014, 11:06 PM
Post Whore
howlinhoss's Avatar
Links to all materials used!
howlinhoss is offline
post #7 of 19 (permalink) Old 10-18-2014, 11:16 PM
Michael V's Avatar
Thanks for the write up. I have a pod filter as well. Been contemplating the ssr block off plate for a long time, but I couldn't find anyone that actually purchased it. Were there any noticeable differences? Power wise, sound?
2014 Ninja 300 ABS SE Red/Black (Totaled)
Mods: Shorty GP Exhaust, Driven Clip-Ons, Yoshimura Rearset brackets, TST Industries LED integrated tailight, TST Industries Fender Elminator, Airbox and snorkel delete, K&N R-0990 Pod Air Filter, AllBalls steering stem bearings, 13/44 Sprockets, Pirelli Diablo Rosso 2 140/60 Rear Tire, Diablo Rosso Corsa 120/70 Front Tire, Power Commander V
2013 Suzuki GSXR 600 Blue(SOLD)
2009 Yamaha R1 Black/Red(Totaled)
2003 Ducati 999
Michael V is offline
post #8 of 19 (permalink) Old 10-18-2014, 11:38 PM
Super Moderator
Spacep0d's Avatar
Added this to DIY thread.
Spacep0d's
2013 Triumph Daytona 675R
Austin Racing V3 Titanium exhaust (baffled), professionally-shaved seat, T-Rex sliders, Pazzo shorty levers, Tech Spec tank grips, tail tidy, Watsen marker lights. Only 23 lbs. heavier than the 300!
Get your ZX-3R decals
Spacep0d is offline
post #9 of 19 (permalink) Old 10-19-2014, 03:16 AM
Sharmo's Avatar
I finished doing this mod today. I used 1/2 inch rubber water plugs from my local auto store to plug the ends.
Sharmo is offline
post #10 of 19 (permalink) Old 10-19-2014, 11:29 AM
I have a pod filter on mine and put the block off plate on and the only time I will hear a backfire is if I'm coming off the throttle and I blip the throttle a little. I don't think that's avoidable though because it's just undetonated gas going off in the exhaust.
Ninja 300 Special Edition
Mods: Yoshimura R-77 Full Exhaust | K&N Pod Filter | Fender Eliminator | Green Progrips | Driven Bar Ends | Micro EFI Tuner | Swingarm Spools | Black Shorty Levers | Woodcraft Clip-ons | Puig Black Windscreen | SV Racing Rearsets | Pirelli DR2 Tires | Shogun Frame Sliders | T-Rex Exhaust Slider | Philips CrystalVision Headlights | R6 Throttle Tube | SSR Block Off Plate | Galfer SS Brake Lines | EBC Sintered Brake Pads
Kairus is offline
Smog Block Off Plates cbzdel Ninja 300 General Discussion 11 03-13-2013 09:48 AM
