Smog Delete Write Up - Page 2 - Kawasaki Ninja 300 Forum
post #11 of 19 (permalink) Old 10-19-2014, 12:59 PM
whirlybird's Avatar
If you don't want to buy the block off plates the ends can just be capped.
MRA #144
Sponsors:
XL3 Rigging, Rider's Discount, Imperial Sportbikes, Un!nk Print works,
whirlybird is offline
post #12 of 19 (permalink) Old 10-19-2014, 01:54 PM Thread Starter
Here is the Block off plate
http://www.slingshotracing.net/catal...ate-p-498.html
The other things that i used were Dorman Bypass Cap Assortment #02253 comes with 8 of them. 4 different sizes and i used the 1/2 caps.
Here are the final pics not so great. Ill do a write up for the Pod Filters as well with links for everything needed. I didnt take to many picture for that one though.
What did you guys do with the valve? same thing i did?
left 2 sensors, blocked off 2 ports, left hose going to throttle body?
mattmid is offline
post #13 of 19 (permalink) Old 01-18-2016, 04:51 PM
Slick_Steveo's Avatar
can't you remove the whole thing? or does the air pump have to remain connected?
Slick_Steveo is offline
post #14 of 19 (permalink) Old 05-07-2016, 08:11 AM
I am so confused about this.
What's the point of smog delete? What are you exactly deleting and why does it fix backfiring problem?
Does it add power? Gas mileage?
Also does it produce more emission?
Timpo is offline
post #15 of 19 (permalink) Old 12-27-2016, 11:11 PM
Metzger's Avatar
Love stirring up an old thread but does anyone know if this improves performance. I don't care about emissions and have a address that requires no emissions test. I have a MGP growler (and baffle) not installed yet. will this reduce noise or increase?
Metzger is online now
post #16 of 19 (permalink) Old 12-29-2016, 02:14 AM
The means of a secondary air system is, that at different operating conditions of the engine fresh air will be supplied into the exhaust (mainly in the decelerating operation) to reduce the emission of pollutants of the exhaust gases (carbon monoxide). Normally this System will be used together with unregulated catalysts.
Important: When one is using any automated remapping system (PCV Autotune etc.) then this system MUST be closed or turned off to avoid any confusion in the measurement.
By the way, your name sounds pretty German-like...
Yoermane is offline
post #17 of 19 (permalink) Old 12-29-2016, 09:44 PM
ClutchDumper's Avatar
Is this a must for a dynotune or flashtune?
2013 White Ninja 300 Adopted on 10/1/16
Mods as of 12/9/16: Plastidipped OEM Windscreen, Shogun Carbon Spools, Woodcraft Clip-ons, ASV C/5 Levers (Long Clutch/Short Brake), Driven D-Axis Grips, R6 Throttle Tube, Healtech Gear Indicator (Red), Techspec Snake Skin Tank Grips, Front Reflector Delete, TST Integrated Programmable Tail light, TST Elite Fender Eliminator, Leo Vince Slip-on, OEm Seat Cowl.
ClutchDumper is offline
post #18 of 19 (permalink) Old 12-30-2016, 12:02 AM
Every time when you need an exact measurement you must eliminate every source which could lead to a wrong result.
Also take to account that one of the most important point is that you always have to keep in mind what type of fuel you use, because this will tell you what the AFR will/has to be!
Just too many guys calculate with 14.7:1 even while they use Ethanol- or Race-Fuel.
Yoermane is offline
post #19 of 19 (permalink) Old 12-30-2016, 02:24 PM
Metzger's Avatar
Yeah it is lol it means Butcher in English a Metzgeria is a Butcher shop in Germany or Kitchener/Waterloo.
Is this a signature
Smog Block Off Plates cbzdel Ninja 300 General Discussion 11 03-13-2013 10:48 AM
