Kawasaki Ninja 300 Stats - Kawasaki Ninja 300 Forum
post #1 of 26 (permalink) Old 10-04-2012, 10:04 AM Thread Starter
Your Kawasaki Ninja 300 Forum Admin
Administrator's Avatar
Kawasaki Ninja 300 Specifications
ENGINE
  • Type 4-stroke Parallel Twin
  • Displacement 296cc
  • Bore and Stroke 62.0 x 49.0 mm
  • Cooling Liquid-cooled
  • Compression Ratio 10.6:1
  • Valve System DOHC, 8 valves
  • Fuel System Fuel Injection: 32mm x 2 (Keihin)
  • Ignition Digital
  • Lubrication Forced Lubrication, wet sump
DRIVETRAIN
  • Transmission 6-speed, return
  • Final Drive Seeled chain
  • Primary Reduction Ratio 3.087 (71/23)
  • Gear Ratio: 1st 2.714 (38/14)
  • Gear Ratio: 2nd 1.789 (34/19)
  • Gear Ratio: 3rd 1.409 (31/22)
  • Gear Ratio: 4th 1.160 (29/25)
  • Gear Ratio: 5th 1.000 (27/27)
  • Gear Ratio: 6th .857 (24/28)
  • Final Reduction Ratio 3.000 (42/14)
  • Clutch Wet multi-disc, manual
FRAME
  • Type Tube diamond,steel
  • Wheel Travel: Front 120mm
  • Tire: Front 110/70-17 M/C 54S
  • Wheel Travel: Rear 132mm
  • Tire: Rear 140/70-17 M/C 66S
  • Caster (Rake) 27
  • Trail 93mm
  • Steering Angle (Left/Right) 35 / 35
SUSPENSION
Suspension, Front 37mm telescopic fork
Suspension, Rear Bottom-Link Uni-Trak with gas charged shock and 5-way adjustable preload
BRAKES
  • Front: Type Single 290 mm petal disc
  • Front: Calipers Single balanced actuation dual-piston
  • Rear: Type Single 220mm petal disc
  • Rear: Calipers Dual-piston
DIMENSIONS
  • Overall Length 2,015mm
  • Overall Width 715mm
  • Overall Height 1,110mm
  • Wheelbase 1,405mm
  • Ground Clearance 140mm
  • Seat Height 785mm
  • Curb Mass** 172kg
  • Fuel Capacity 17 litres ** Includes all necessary materials and fluids to operate correctly, full tank of fuel (more than 90% of capacity) and tool kit (if supplied)
PERFORMANCE
  • Maximum Power‡ 29.0 kW {39PS} / 11,000
  • Maximum Torque‡ 27.0 Nm {2.8 kgfm} / 10,000 rpm ‡ Power / Torque figures measured at the crankshaft.
DETAILS
  • Warranty 12 months warranty
Administrator is offline
The Following 3 Users Say Thank You to Administrator For This Useful Post:
bugsynbetsy (12-17-2012), Rollbar (01-05-2015), White-Fury (01-17-2013)
post #2 of 26 (permalink) Old 10-04-2012, 11:14 AM
cfrp's Avatar
great rundown of the known specs. Once its available someone should throw up the user manual. Things like bulb sizes, fluid capacity, torque settings, maintenance schedule would be a great addition in the future.
Pavel likes this.
niiinnjaaaaaaaa
cfrp is offline
post #3 of 26 (permalink) Old 10-04-2012, 11:22 AM
cbzdel's Avatar
I was thinking the same thing, but I do not have internet at home, so I am only able to post via mobile device unless I am at work.
cbzdel is offline
post #4 of 26 (permalink) Old 10-17-2012, 10:03 PM
Oh, those would REALLY come in handy!
leslieliang is offline
post #5 of 26 (permalink) Old 12-17-2012, 07:17 PM
ABS brake (linked?)
Is ABS brakes available as an option in North America? I am a newbie to the sport and ABS brakes preferably linked is a must for me.
bugsynbetsy is offline
post #6 of 26 (permalink) Old 12-17-2012, 07:36 PM
Yes it is, only on the SE (green/black) in the US.
Sent from my SCH-I510 using Motorcycle.com Free App
Lienmarine is offline
post #7 of 26 (permalink) Old 12-31-2012, 09:01 PM
KrispyKreme's Avatar
you can get the black or white 300 with ABS as well.
2013 Ninja 300 (Black)
KrispyKreme is offline
post #8 of 26 (permalink) Old 12-31-2012, 09:19 PM
Hero of Time
phrenetiK's Avatar
the white does not have ABS in the USA
phrenetiK is offline
post #9 of 26 (permalink) Old 01-01-2013, 12:19 AM
Neither does the black in the US.
nuccifamily is offline
post #10 of 26 (permalink) Old 01-01-2013, 01:19 AM
-dondae-'s Avatar
Send a message via Yahoo to -dondae- Send a message via Skype™ to -dondae-
... Lime green/ ebony is the only way to go for abs
-dondae- is offline
Regular Kawasaki Ninja 300 or Ninja 300 with ABS? kawasaki-ryder Ninja 300 General Discussion 63 02-28-2017 09:04 AM
Kawasaki NINJA 300 Special Edition & NINJA 636 ZX6R Side by Side Physical Comparison Ghost_Rida Kawasaki Ninja 300 Videos 1 12-03-2012 10:06 AM
2013 Kawasaki Ninja 300 Press Introduction - Kawasaki TV cfrp Kawasaki Ninja 300 Videos 0 10-26-2012 06:50 AM
2013 Kawasaki Ninja 300 & Ninja 300 ABS Colors kawasaki-ryder Ninja 300 General Discussion 0 09-28-2012 03:56 PM
Kawasaki Ninja 300 Ghost_Rida Kawasaki Ninja 300 Videos 0 09-28-2012 11:49 AM
