Kawasaki Ninja 300 Stats - Page 3 - Kawasaki Ninja 300 Forum
post #21 of 26 (permalink) Old 07-12-2015, 02:37 AM
Originally Posted by swimmer_spe View Post
My 2014 manual calls for 86 Octane. I have been using midgrade - 87 Octane.
Looking at the compression ratio, I almost want to put in 89 or higher. Besides engine knock, which the computer should be able to adjust for, does a higher octane give me anything better? Has anyone used it and seen better mileage or anything else?
This has been discussed extensively on this, and other, forums. Running higher than 87 is not beneficial in any way. It doesn't have more energy, it won't give you any gains, it'll just waste your money and possibly cause the bike to run less efficiently. The only reason to run 89 or 91 is if you're using an aftermarket fuel management unit with a map that was tuned by the company using a higher octane fuel, in which case the fuel and ignition timing has been tuned to compensate for any differences in flame propagation etc.
It is important to note that the quoted 87 octane number only applies to the US/Canada which use the (R+M)/2 rating method. Other countries may use a different rating method, such as Australia and most of Europe which use the RON rating. 87 in the US/Canada is equivalent to 91-92 RON, so make sure you check the rating method posted on the pump if you're in another country or you may get engine knocking from using a fuel with too low of an octane rating.
White 2014 Ninja 300 SE ABS: Pirelli Diablo Rosso IIs (stock sizes), Power Commander V (fuel and ignition), K&N filter, Yoshimura R-77 carbon fiber full exhaust, adjustable rearsets, 15w fork oil
twistywrist is offline
The Following User Says Thank You to twistywrist For This Useful Post:
swimmer_spe (07-12-2015)
post #22 of 26 (permalink) Old 04-25-2016, 12:48 PM
I would respectfully point out that this is not the whole picture. As many things often are about internet wisdoms, it is more complex than many like to state.
The first thing is that octane ratings are first and foremost a guide for us about how easy/difficult it is to ignite the gas. Everyone knows that part. There is no caloric benefit to a higher octane. There is a difference however how fast the flame front travels, especially if there is ethanol in the mixture. Thus most of the time one can put in a LOWER grade, even than is recommended and mostly, on todays electronically controlled engines you will not get pinging until extremes are reached. Ever notice how compression has gone up, and with it, it used to mean that you needed an octane boost, but nowadays all of a sudden the same compression often does NOT need a higher octane. As one poster eluded to already the engine management system can take care of moderate levels of sub-optimal ignition. It is how it does it that can be a problem, depending on your point of view. Basically the engine advances the ignition. No pinging - but at extremes I don't think you get full full gas burn, and it leans it out at the same time. Net effect is that you lose a bit of power with engine tech saving our butt. That of course is much better than pinging but you but if power potential goes down, maybe higher octane is net beneficial? It actually gets more complicated than just that, and I don't understand much of it, but as a simple addition to conventional debates it is a small point worth adding.
If you ride a fairly new bike and ride is a relatively relaxed manner run what you want works. As the carbon builds and engine wears (oil burn also affects all of this minutely) or if you ride like a true Green-Blooded-Ninja-Squid, then higher octane is not completely wasted. Besides rubber probably costs more than the premium cost of the fuel.
As far as ethanol, supposedly engines are formulated for it. What I find odd is that different bodies (used to anyways - I don't know nowadays) have different ideas as to how much is too much. That tells me that to some degree it is harmful and so, seeing the fact that I LIKE my Ninja, I pay the extra price and go to the extra effort to find and use the "real" stuff.
Ethanol has a lower caloric value, btw, so if everything was equal there would always be more power in pure gas. But things are not equal. Ethanol is oxygenated and that flips things upside down. You still have less calories so less potential for work, but the flame now burns very quickly and is suitable for very high rpm's and lower emissions. I do believe that all of this goes hand in hand with learner mixtures and so oil is probably much more important nowadays. So go figure, I'm not sure of what final conclusions to draw. It might be worth a mention that Ethanol is hygroscopic whereas gas is not, so adding heet once in a while may be a good idea, or does anyone know if there are additives in the ethanol gas for that already?
I run two or three tankfuls of ethanol free back to back about twice a year in my Miata with its well worn 180,000 engine, ever since my mechanic suggested it, and it really seems to make the engine run smoother and the idle more even. It would never have though that, but I don't think its my imagination, especially the idle which is obvious.
Good topic - I'd love to know more about it.
Last edited by Pavel; 04-25-2016 at 12:54 PM. Reason: got it backwards, mea culpa.
Pavel is offline
post #23 of 26 (permalink) Old 04-25-2016, 12:52 PM
Does anyone know how much the alternator in our N300's puts out and at what rpm? I can't see to find that detail anywhere.
Pavel is offline
post #24 of 26 (permalink) Old 06-06-2016, 09:10 PM
Dude, this post was elegant and very well thought out. I would really, REALLY like to see your questions answered by someone who knows the answers. I did not know that current engines are more adequate at high compression to avoid pre-detonation.
jcgss77 is offline
post #25 of 26 (permalink) Old 12-06-2016, 06:17 PM
I've heard from different sources that top speed is 165 kph, while others say they've gone up to 180. Anyone care to comment on that? What's been your top speed?
Ghostface is offline
post #26 of 26 (permalink) Old 12-06-2016, 06:22 PM
vulgr's Avatar
I've hit 182 (gps) at my local racetrack (downhill straight), I've seen >200 with different gearing (different track, no massive elevation change on the straight)
amateur racer #128
race sponsor-
vulgr is online now
Regular Kawasaki Ninja 300 or Ninja 300 with ABS? kawasaki-ryder Ninja 300 General Discussion 56 09-25-2016 10:31 PM
Kawasaki NINJA 300 Special Edition & NINJA 636 ZX6R Side by Side Physical Comparison Ghost_Rida Kawasaki Ninja 300 Videos 1 12-03-2012 11:06 AM
2013 Kawasaki Ninja 300 Press Introduction - Kawasaki TV cfrp Kawasaki Ninja 300 Videos 0 10-26-2012 07:50 AM
2013 Kawasaki Ninja 300 & Ninja 300 ABS Colors kawasaki-ryder Ninja 300 General Discussion 0 09-28-2012 04:56 PM
Kawasaki Ninja 300 Ghost_Rida Kawasaki Ninja 300 Videos 0 09-28-2012 12:49 PM
