Kawasaki Ninja 300 Stats - Page 2 - Kawasaki Ninja 300 Forum
post #11 of 26 (permalink) Old 03-10-2013, 01:24 PM
nice post
svt_kawi is offline
post #12 of 26 (permalink) Old 03-10-2013, 02:29 PM
pastry's Avatar
Here in SA we've got a 24 month warranty
pastry is offline
post #13 of 26 (permalink) Old 04-04-2013, 10:29 AM
Angry_Throttle's Avatar
24 month warranty in Australia
Angry_Throttle is offline
post #14 of 26 (permalink) Old 05-23-2013, 10:42 AM
Originally Posted by bugsynbetsy View Post
Is ABS brakes available as an option in North America? I am a newbie to the sport and ABS brakes preferably linked is a must for me.
Yes only in the SE . Also some dealers don't usually carry the ABS model so you might have to ask the dealer to order it for you.
sugarh2oprpl@gmail.com is offline
post #15 of 26 (permalink) Old 08-21-2013, 09:56 PM
Spark Plug: NGK CR8E (stock) GAP: 0.7-0.8mm (0.028-0.031in)
Oil Capacity:2.5 Quarts (2.4L) 10W-40
Oil Filter Torque: 12.9 ft lb (1.78 kgf/17.5N)
Oil Drain Bolt Torque: 14.5 ft lb (2 kgf/19.6N)
Coolant Capacity: 1.6 Quarts (1.5L)
Fuel Tank Capacity:4.5 Gal (17L)
Fuel Requirement: Minimum 87 Octane (Including Cali Models)
(Note the manual states if you notice knocking or pinging, switch brands of gas AND use a higher octane gasoline)
Alternate Fuels: Gasoline containing UP TO 10% Ethanol - Gasoline containing UP TO 15% MTBE - Gasoline containing UP TO 16.7% TAME and 17.2% ETBE
Tail/Brake Light: 12 V 5/21 W
Headlight: 12V 55W
Battery: <12.6 volts - needs to be charged or replaced
Recommended Idle Speed: 1250-1350 rpm
Clutch Lever Play Recommendation: 0.08-0.12in (2-3mm)
Drive Train Slack: 0.8-1.2 in (20-30mm)
Axle Nut Torque: 72 ft lb (10kgf/98Nm)
Tire Tread Depth (Minimum): Front/Rear (Under 80mph)
0.04in(1mm)/0.08in(2mm)
Front/Rear (Over 80mph)
0.04in(1mm)/ 0.12in(3mm)
(It should be noted 90% of tire failures occur in the last 10% of tire tread life)
Brade Pad Wear (Lining limit): Front/Rear - EX300A
0.06in(1.5mm)/0.06in(1.5mm)
Front/Rear - EX300B
0.04in(1mm)/0.06in(1.5mm)
Recommended Brake Pedal Travel: 0.4in(10mm)
Tire Pressure (When Cold): Front/Rear
28psi(200kpa, 2.0 kgf)/32psi(225kpa,2.25kgf)
Will add other pertinent information when I can compile it. Trying to find a standard part number (aside from what kawa assigns them) for all the bulbs on the 300.
Ride Safe!!
**Side note, if you notice on your ABS bike, if the light comes on and STAYS on after starting, this means there is a fault in your ABS and IS NOT FUNCTIONING** Per the owners manual.
Pavel likes this.
CCW Ninja LAS is offline
The Following 4 Users Say Thank You to CCW Ninja LAS For This Useful Post:
ClutchDumper (12-06-2016), dantastic (02-28-2015), Rollbar (01-05-2015), swimmer_spe (07-11-2015)
post #16 of 26 (permalink) Old 08-21-2013, 10:13 PM
Super Moderator
jeff's Avatar
It is normal for your ABS light to stay illuminated after you have started the bike.
Only when you have begun moving and the ABS unit is receiving pulses, will the ABS light go off.
If you have begun riding, and your ABS light is still illuminated, you have an issue with your ABS as mentioned above.
jeff is offline
The Following User Says Thank You to jeff For This Useful Post:
CCW Ninja LAS (08-22-2013)
post #17 of 26 (permalink) Old 08-22-2013, 01:34 AM
That is what I meant, thanks for clarifying for anyone who misunderstood.
The Following User Says Thank You to CCW Ninja LAS For This Useful Post:
jeff (08-22-2013)
post #18 of 26 (permalink) Old 08-22-2013, 02:30 AM
People should stop saying E10 is bad for these biles, it will fine as the user manual states, it will lean out by 3% but the default map is rich enough. and beside the higher octane in E10 will help if you have detonation issues and the ethanol will run your engine slightly cooler
Mods - INSTALLED: Healtech GIpro DS, Yoshimura full exhaust, K&N panel filter, Snorkel delete + modded airbox, 1" bar raiser, 15T Sprocket, Yoshimura frame slider, Power Commander 5, BKmoto projectors, Michelin Pilot streets, Galfer SS brake lines, EBC brake pads, Penrite DOT 5.1 brake fluid, Oxford heated grips, Base canned map 35.9hp / Dyno tune @ 40.7hp on 95 E10 / NEXT MOD: Tokico 4pot caliper
Arcticsoldier is offline
post #19 of 26 (permalink) Old 04-30-2014, 06:56 PM
This was super helpful when I was getting acquainted with my bike.
fudgeDredd is offline
post #20 of 26 (permalink) Old 07-11-2015, 11:25 PM
swimmer_spe's Avatar
My 2014 manual calls for 86 Octane. I have been using midgrade - 87 Octane.
Looking at the compression ratio, I almost want to put in 89 or higher. Besides engine knock, which the computer should be able to adjust for, does a higher octane give me anything better? Has anyone used it and seen better mileage or anything else?
2014 Ninja 300
1968 Hodaka Ace 90 - My fathers old bike (currently in pieces.)
swimmer_spe is offline
Regular Kawasaki Ninja 300 or Ninja 300 with ABS? kawasaki-ryder Ninja 300 General Discussion 63 02-28-2017 09:04 AM
Kawasaki NINJA 300 Special Edition & NINJA 636 ZX6R Side by Side Physical Comparison Ghost_Rida Kawasaki Ninja 300 Videos 1 12-03-2012 10:06 AM
2013 Kawasaki Ninja 300 Press Introduction - Kawasaki TV cfrp Kawasaki Ninja 300 Videos 0 10-26-2012 06:50 AM
2013 Kawasaki Ninja 300 & Ninja 300 ABS Colors kawasaki-ryder Ninja 300 General Discussion 0 09-28-2012 03:56 PM
Kawasaki Ninja 300 Ghost_Rida Kawasaki Ninja 300 Videos 0 09-28-2012 11:49 AM
