How much can a battery handle? - Kawasaki Ninja 300 Forum
 7Likes
post #1 of 18 (permalink) Old 06-15-2017, 07:50 PM Thread Starter
ClutchDumper's Avatar
Hey guys,
So I'm currently still using the original battery that came with the bike. I have little to no knowledge of how electricity works but I was hoping you guys can help me out with my concerns.
I currently have one battery tender quick disconnect attached to my battery. However, I have an LED underglow kit on the way, the bkmoto head light assembly, and plan on installing another quick disconnect to route to the front of my bike for a usb charger. I might just get an extension cable to route from my truck space to the front but there might be too much excess wire. The thing about my underglow kit is that I'm specially wiring it to be able to control one part of the bikes lights with one switch and the rest of the bike with another which requires me to connect 2 connectors in total to the battery just for the kit. After this all, it sound like I'm gonna be having 5 rings connected to my battery.
Has anyone done this much to their bike? Can the stock battery handle it? Or will I need to upgrade?
Thanks!
2013 White Ninja 300 / ZX3R
Too many aftermarket parts to list.
ClutchDumper is offline
post #2 of 18 (permalink) Old 06-15-2017, 09:44 PM
Better question might be if the OEM stator can keep up with all of that.
post #3 of 18 (permalink) Old 06-15-2017, 10:44 PM Thread Starter
Rookie question here but what's the stator for?
Sent from my iPhone using Tapatalk
post #4 of 18 (permalink) Old 06-15-2017, 11:18 PM
xorbe's Avatar
More or less, the battery is for powering the ecu and starting the bike initially. The stator is for recharging the battery after starting, and then it also powers everything else, while the engine is running. If the stator can't keep up, then the battery will eventually drain to zero while you are riding, and all the fun comes to a stop!
Rogue likes this.
xorbe is online now
post #5 of 18 (permalink) Old 06-16-2017, 12:38 AM Thread Starter
Oh god speaking of ECU's I'm also gonna have a PCV attached to my battery soon too.. I don't on riding on the streets with the underglow on but maybe occasionally on a night group ride if any or just to turn it on while pulling into a meet. But still I don't wanna end up having my bike run out of power haha
But anyway, is there like a specified capacity to how much the stator can withstand?
post #6 of 18 (permalink) Old 06-16-2017, 01:10 AM
sparkcycle's Avatar
I can't answer your question about the stator capacity, but you can shed some of the load by changing all your bulbs to LED so that they draw a fraction of the power of the filament bulbs.
ClutchDumper likes this.
Engineer rocketing through time and space on a Ninja 300 ABS
sparkcycle is offline
post #7 of 18 (permalink) Old 06-16-2017, 01:52 AM Thread Starter
Sounds about right. The only lights that aren't LED right now are my front turn indicators. All the lights in the BKmotos should be LED as well I believe.
post #8 of 18 (permalink) Old 06-16-2017, 02:03 AM
It's not that hard to calculate:
Low-Beam 55 Watt
Hi-Beam 55 Watt
ECU and Fuel-Pump 96 Watt
Taillight 5 Watt
just to name a few and have a starting point.
The stator from the EX300 charges with 294 Watt (EX250-FI = 322 Watt).
Yoermane is offline
The Following User Says Thank You to Yoermane For This Useful Post:
ClutchDumper (06-16-2017)
post #9 of 18 (permalink) Old 06-16-2017, 05:07 AM Thread Starter
Low-Beam 55 Watt
Hi-Beam 55 Watt
Taillight 5 Watt
Okay so what I understand now is to find the wattage from each accessory and add it all up and if I'm under 294 watts in total I should be okay?
post #10 of 18 (permalink) Old 06-16-2017, 09:59 AM
The BKMoto lights are HID correct? I installed the H7 kit from him. HIDs require less wattage to run per bulb after it has fired up but it needs a temporary large draw when starting. According to his site the H7's are 35w a piece so:
70w Headlights
56-60w Heated grips
15w phone charger
12w Go pro charger
77w heated liner
96w FP/ECU per Yoermane
->330w draw when heated elements are at full blast
?w switchback light strip 2x
?w switchback halo x2
?w white halo x2
?w led tail light
I always run my heated gear at about 50-70% when ever I do so normally at night I'm barely charging the battery. During the day i have the HIDs switched off as the morimoto halos I have are bright enough in my opinion to be used as DRLs, and switch the HIDs on with highs when I lane split. With the HIDs off and no heated gear the bike charges up very quickly.
Not sure what your setup is, but unless you ordered your headlight with the color changing LEDs, the rings are most likely CCFLs, which if i remember correctly, draw more than LED equivalents. I have no idea what the wattage is for either but its probably negligible in the grander scheme.
And I have like 8 things on the positive terminal. I need to switch to a distribution block but apparently my brain doesn't mind sitting on top of a fire hazard.
Lacrossev is offline
FYI: Battery Tender Junior/Battery Tender USB port dh300 Ninja 300 Parts & Accessories 0 08-03-2015 01:20 PM
How to handle the driveway? Alley Cat New Rider Section 16 12-27-2014 03:06 PM
Bike battery went flat. Got a new battery and died an hour later Senzuri Ninja 300 Issues and Troubleshooting 16 11-06-2014 08:19 AM
Car Battery-Motorcycle Battery Boast cantwaitformyride Ninja 300 General Discussion 4 08-06-2013 12:35 PM
broken clutch handle ryan8616 Ninja 300 General Discussion 2 06-17-2013 04:22 AM
