Changed front brake pad, having trouble...help! - Kawasaki Ninja 300 Forum
post #1 of 7 (permalink) Old 04-14-2017, 02:21 PM Thread Starter
amonsa's Avatar
Hi all,
I just installed EBC FA197HH pads for my front brakes. I went out to test them and something is not right. There doesn't seem to be any issues under normal braking but under hard braking the pads don't seem to catch right. They make a squeaking noise and seem to skip a bit, like they're struggling for grip. I'm very familiar with the ABS system, so I'm sure it's not the ABS kicking in.
Anybody have any ideas?
amonsa is offline
post #2 of 7 (permalink) Old 04-14-2017, 06:42 PM
How recently? You need to bed them in, which takes several hundred miles of stop /go city riding plus a few hard braking cycles in a row after that. Check their websites for info.
I have those pads and they were scary bad at first, though I don't remember what you describe.
Sent from my Pixel using Tapatalk
2014 Ninja 300 ABS - Black
Akrapovic Titanium Slip On | Decatted Exhaust | FlashTune ECU | Shogun Frame Sliders | Michelin Pilot Street Radials & EBC HH brake pads | Puig Windscreen & Tail Tidy | Custom LED Integrated Tail Light | Red Shorty Levers | Oxford Heaterz Sport Grips | Red Plasti-dipped Rear Foot Peg Brackets | Red CustomTaylor33 reflective rim tape + Ninja & Kawasaki Logos | Red SSR Frame Plugs & Swingarm Spools | 1" Mirror Extenders
ninjared is offline
post #3 of 7 (permalink) Old 04-14-2017, 10:49 PM
vulgr's Avatar
I Always scuff up the brake disc with some sandpaper when changing to another brand/type of pad. I also bleed the brakes and do a 2nd bleed a couple of days later. I've never had any issues so far.
In my opinion the standard EBC HH pads really suck though
amateur racer #128
race sponsor-
vulgr is offline
post #4 of 7 (permalink) Old 04-15-2017, 09:37 AM
accumack's Avatar
Did you clean the rotor? You may have some oil, grease, or skin oil on the rotor. Also the the pads take a few hundred miles to get the most grip(bedding in). There is a process to bed them in do a google search. Once bedded in they have very good grip.
Mods: Nelson-Rigg cl-2020 tank bag, Driven clip-ons 10 degrees, Pirelli Diablo Rosso II now Michelin Pilot street radial tires stock sizes, 2006 GSXR600r rear shock, sag front and rear set, mirror extenders, rear seat cowl, Flo reusable oil filter, Green shorty levers, EBC HH Pads, Galfer braided front brake line,Motul brake fluid.
accumack is offline
post #5 of 7 (permalink) Old 04-15-2017, 09:43 AM
Rttoys's Avatar
I agree with vulgr on preping the rotors.
Give the rotor a cleaning with some brake clean on a rag (one without any oil on it). Then, scuff it with some sandpaper. Clean it one more time to get sanding residue off.
Since you used the pads already, give the pad surface a light sanding too (just enough to scuff it up), then burn them in.
Here's a good article and video from revzilla on it.
https://www.revzilla.com/common-trea...ge-your-brakes
I have HH pads on my 996. They are a little "grabby", but seem to work well on the track.
Track-
'13 Kawasaki Ninja 300SE - Yoshi exhaust, Vortex rear sets, gp shift, Bridgestone Battlax S20 EVO, GSXR rear shock, Barnett clutch and springs, Woodcraft clip-ons, Hotbodies race plastics, Ducati steering dampener, fully safety wired, more to come.
'99 Ducati 996s- a bunch of hard to pronounce and hard to spell add-ons.
Street-
'14 Yamaha TW200
'07 Yamaha FZ1
'08 Ducati Hypermotard
Rttoys is offline
post #6 of 7 (permalink) Old 04-15-2017, 09:12 PM
DDub's Avatar
Usually the previous pads leave crap all over the rotors (glaze). When you change pads, you should deglaze your rotors too. Here's a good video:
http://www.motorcyclistonline.com/ho...tors-mc-garage
HID Kit w/ Halos - RaceTech Springs - Spiegler SS Brake Line - Pazzo Shorty Levers - Woodcraft Clipons - Driven D3 Grips - Yoshi R77 Full - K&N Air Filter - Dynojet Micro - Vortex 40T Alum Rear Sprocket - Seat Cowl - Motodynamic ITL and FE - Yoshi Rear Set Brackets, Frame Sliders and Bar End Sliders - Shogun Swingarm Sliders - R&G Engine Case Covers and Fork Sliders - TechSpec Tank Grips - Progrip Tank Pad - Pirelli DRII Tires - Shorai Battery - ZG Corsa Windscreen - Saddlemen Chicane Seat
DDub is offline
post #7 of 7 (permalink) Old 04-20-2017, 06:18 PM
Originally Posted by amonsa View Post
Hi all,
I have the same pads. They weren't as bad as you describe but under hard braking they felt worse than the factory pads when I first installed them. Now that I have about 200 miles or so on them they are better under hard braking. My guess would be a small upgrade over stock. It took some time to get there though.
in_the_midwest is offline
New brake pad options KiaAngelo Ninja 300 Parts & Accessories 5 03-12-2017 01:07 PM
Newbie Brake Pad Question autummatic45 Ninja 300 Parts & Accessories 16 09-18-2015 11:01 AM
Brake Pad Question for newbie Shinji2009 Ninja 300 General Discussion 11 01-03-2015 10:04 PM
Changed Brake Lines, help please? 296virgins Ninja 300 Appearance & Modifications 2 09-11-2014 11:02 PM
Front brake pad rubbing against disk rodcar125 Ninja 300 General Discussion 5 11-05-2013 08:35 PM
