Long Distance Ride Advice - Kawasaki Ninja 300 Forum
post #1 of 15 (permalink) Old 02-14-2017, 03:48 PM Thread Starter
KawiGirl67's Avatar
Send a message via Skype™ to KawiGirl67
I'm getting ready to make a 2600 mile ride on my new-to-me little Ninja. I'm having her serviced before leaving. I have gotten a pair of Nelson-Rigg hi-vis saddlebags, a spare pair of brake/clutch levers, a mount for my phone/gps, a Zero Gravity sport touring windscreen, luggage rack, round mirror insets to hopefully improve visibility (boy, these mirrors are CRAP as is...it's my only complaint about the bike so far), the tool kit, and a pressure gauge. Is there ANYTHING else that I should have that I'm not thinking of right off hand? Thanks for any advice!
**edited to add that I want to get a bluetooth headset for the lid...any recommendations??
KawiGirl67 is offline
post #2 of 15 (permalink) Old 02-14-2017, 04:19 PM
I got a Sena 3s bluetooth. It's the cheapest and works very well. The only thing is I can't pair it to other Sena users but I don't ride in groups. depending on how long you'll be on the road, you may have to ride with it charging and alternate the charger with your phone so make sure you have a long enough charging cable.
Get a tire inflator and plug kit from walmart or Autozone. Many riders refuse to use plugs but in a pinch it's better than sitting on the side of the road. I've put thousands of miles on plugged tires over the years and never had a problem, so I'm not against them at all.
paper towels, rubber gloves, and chain lube. I do mine at the end of the day when I go on road trips, usually around 450-650 miles/day.
USB charger, but try to find a good one. The Deltran one I bought charges at a super slow rate that the phone will still lose power when plugged in and using GPS simultaneously. it could be that I just got a faulty one. this one looks good: http://www.twistedthrottle.com/bikem...FduIswod7jQNvw it comes with the battery adapter cable. be sure to charge your phone where it gets some ventilation.
how many miles on the bike? check your brakes, and at every fill up check your oil level and chain slack.
Tools to adjust your chain.
1uglybastard is offline
The Following User Says Thank You to 1uglybastard For This Useful Post:
KawiGirl67 (02-16-2017)
post #3 of 15 (permalink) Old 02-14-2017, 05:35 PM Thread Starter
KawiGirl67's Avatar
I picked up this one... https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Had some good reviews and if it does well, I can get one for the hubby...
Great idea...yeah, I'm not against a plug to get me as far as a service shop to replace the tire.
Chain lube!! Yesss, thank you. Definitely want all those you've mentioned...plus some extra cotter pins just in case.
The phone mount I got has a single usb port. I'm planning to wire it to the headlight (even though it has an off switch). I know my route...I've made so many cross-country trips, I should have a section of Interstate named after me by now...so, I'll only have the gps on long enough to navigate me thru the cities the fastest way. My main thing will be powering the bluetooth alternately with my phone for Pandora.
The bike has 18k at this point. Going to have my bike mech here give her a once over to check everything and fix whatever might need attention. I'll need to make sure the tool kit has everything needed for the chain...bought the bike used last week, so I need to go over that kit.
Thanks so much for the advice!
post #4 of 15 (permalink) Old 02-14-2017, 06:16 PM
Brion B's Avatar
That is one heck of a ride on a Ninja 300 or any bike actually.Enjoy the trip and ride safe.
2014 Ninja 300 SE Pearl StarDust White With ABS
Two Brothers Tarmac Carbon Slip On
TST Industries Integrated Taillight/Signal Lights
TST Industries Fender Delete Kit
K&N Air Filter
OEM TailBag
Adjustable Clutch/Brake Lever
2016 Vulcan 900 Custom
Cobra FI2000R Fuel Controller
Kuryakyn Voltmeter
Kawasaki Mini Tachometer
K&N Air Filter
Kuryakyn ISO Grips With Dual Throttle Bosses
Easybrackets
Cobra Freeway Bars
DesertDawg Freeway Bar Chaps
Mustang Wide Vintage Touring Seat With Drivers Backrest
Brion B is offline
The Following User Says Thank You to Brion B For This Useful Post:
post #5 of 15 (permalink) Old 02-14-2017, 07:15 PM Thread Starter
KawiGirl67's Avatar
Thanks Brion! Yeah, even my own mom said, "omg you are cra cra". I about died laughing at the slang. Told her the apple didn't fall far from this particular tree...
post #6 of 15 (permalink) Old 02-15-2017, 07:38 AM
the valves are supposed to be checked at 15k miles according to the manual. some people don't worry about it, but a few have said they needed them adjusted. it's not a cheap job, but I heard it's not too hard to at least inspect them if you're handy with a wrench. Just something for you to consider.
can you post a link to the phone mount you got? mine just holds the phone; it doesn't have any kind of charging connection. where do you plan on mounting it? I didn't have room on my bars for mine so I attached it to the rear view mirror.
post #7 of 15 (permalink) Old 02-15-2017, 08:51 AM
sabbath666's Avatar
Not that it is absolutely required, but to be on the safe side, you can carry a fuel bottle, just in case.
Something like: https://www.amazon.com/MSR-MSRFUELBO...GE6?th=1&psc=1
Keep the rubber side down
sabbath666 is offline
The Following User Says Thank You to sabbath666 For This Useful Post:
post #8 of 15 (permalink) Old 02-15-2017, 09:45 AM
i thought about recommending the fuel bottle as well.
If you don't want to spend the money or have to lug the bottle around, I recommend figuring out the fuel mileage on your bike and when is a good time to fill up. My fuel gauge would start blinking at 190 hwy miles. At that point, I still had about 55 miles before it was empty. Staying on the interstate made it easy to find gas. You have to be vigilant of signs that say there are long stretches of no services, though. I remember after Ft Stockton, Tx there was no gas for 80 miles along I-10; that'd be a bad stretch to be running on fumes.
another option is using a temporary bottle. I once used a Mt Dew wide mouth liter bottle to hold me over until I got to my destination.
post #9 of 15 (permalink) Old 02-15-2017, 11:53 AM Thread Starter
KawiGirl67's Avatar
I ordered this one...arrived yesterday. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I plan to mount it under the windscreen (kinda difficult to explain the idea I had for that), maybe using one of the side mirror bolts if possible...otherwise I'm just going to drill a hole in the fairing next to the windscreen and attach it with a bolt/washers. I'll take a pic once I've got it on there! But I am REALLY happy with this mount! It is solid and holds the phone VERY tightly...I loaded my phone in there and shook it all around...no play at all.
I'll mention the valves to my mech...hopefully they will be good to go. The guy I got the bike from was also a mech and had the bike at a track day a couple weeks ago...so I'm thinking it might be in pretty good condition? Who knows.
Good idea, thanks! There are definitely some long stretches without fuel available, and I don't know how far I can push the bike yet. Not going to take any chances though...and I figure I'm going to need to get off and stretch every couple hundred miles anyway.
Last edited by KawiGirl67; 02-15-2017 at 12:02 PM. Reason: Forgot link cause I haven't had me coffee...
post #10 of 15 (permalink) Old 02-15-2017, 05:00 PM
Maybe a small first aid kit, duct tape, and zip ties?
tropicalbob is offline
The Following User Says Thank You to tropicalbob For This Useful Post:
Long distance on the Ninja 1uglybastard Ninja 300 General Discussion 16 07-10-2016 08:36 PM
Long distance travel Squid Ninja 300 General Discussion 9 12-23-2015 06:56 PM
Long distance riding tips. JayD Riding Tips and Techniques 17 09-03-2015 10:46 AM
Long distance...pain...Aftershock 2014 Malice101 Off-topic Discussion 11 09-19-2014 09:20 PM
Replacement Long-Distance Tires cheguevara Ninja 300 Parts & Accessories 26 04-03-2014 07:15 PM
