Oil change DIY - Page 3 - Kawasaki Ninja 300 Forum
Closed Thread
post #21 of 64 (permalink) Old 01-09-2013, 04:39 PM
I ♥ Borat In A Thong
NoD GP's Avatar
Originally Posted by DaveTheCanuck View Post
Some oil hits the pipe when you pull the filter, even if you're using a rear stand or center stand.
Trick is to cover your pipe with some aluminium foil. Once you put the new filter on, just pull the foil off. Bam, clean pipes.
I used foil and when I went to take it off I slid it funny and still got some on my pipe lol
Sent from my DROID RAZR using Motorcycle.com Free App
Where's the toilet paper you terrorist?
NoD GP is offline
post #22 of 64 (permalink) Old 01-09-2013, 09:51 PM
Originally Posted by phrenetiK View Post
lol wilhelm you are now awesome in my book XD
Haha. Well thank you, I remember when I went to see Jamie's elsewhere play with my friends band burn bright Apollo here in vegas. I'm so sad Aaron quit the band for of mice and men tho.
Wilhelm_ryan is offline
post #23 of 64 (permalink) Old 01-09-2013, 10:44 PM
JerzKawiKid's Avatar
I hate those filter sockets! You really should never need one.. The oil filter should be hand-tight plus 1/4 turn. And thumbs up for the tri-force!!!
JerzKawiKid is offline
post #24 of 64 (permalink) Old 01-09-2013, 11:18 PM
DaveTheCanuck's Avatar
You'll need one (or some tool) to remove the stock filter. It is cranked on.
2013 Kawasaki Ninja 300 - Track bike
2011 Yamaha XJ6N - Daily driver
DaveTheCanuck is offline
post #25 of 64 (permalink) Old 01-11-2013, 08:05 AM
eXZet's Avatar
I bought a oil filter strap wrench to take it off, didn't work at all and i ended up bend the oil filter. Now I have to look for other tool
in that video it looks so easy with that tool! **** oil filter now my bike has no oil in it and have to wait until i found the right tool to take it off.
Do you guys now the size of the wrench I should get?
Ninja 300 SE - She's awesome
eXZet is offline
post #26 of 64 (permalink) Old 01-11-2013, 09:05 AM Thread Starter
Hero of Time
phrenetiK's Avatar
sorry I'm not sure what size since mine is adjustable :\ i saw at the kawasaki dealer he had 2 options..OEM expensive one or a knock off cheaper version but both would work...i would just ask wherever you buy your filter from.
phrenetiK is offline
post #27 of 64 (permalink) Old 01-11-2013, 09:18 AM
dkw12002's Avatar
An oil filter strap wrench should work very well. Mine is straight with a protective rubber cap on one end and is made of seat-belt material. What you do is put your socket wrench into the open end of it and ratchet it off since the bar is the same size as your socket wrench....1/2 inch. I've never had one fail me yet and there is always room for it on any bike cause you can slide it on. If you try to do it any other way, such as use a screwdriver in the open hole on the bar or attach an adjustable wrench or something to try and remove it, it might not work cause the strap just tends to slide. Use your socket wrench! You will have to take the lower fairing off to get your hands in I think, but that's a snap...no wait. 2 snaps.
dkw12002 is offline
post #28 of 64 (permalink) Old 01-11-2013, 02:15 PM
Do what I did...
Just jab a flathead screwdriver through it (you might need a mallet to punch it in). Once it's in, use the handle of the screwdriver to twist it off.
There's not much point in buying a tool for it, you only need it to remove the stock filter. Afterwards, you should only be hand tightening the filter.
The Following User Says Thank You to DaveTheCanuck For This Useful Post:
SClown (01-14-2013)
post #29 of 64 (permalink) Old 01-14-2013, 09:15 PM
Nice video!
Btw, don't forget run the bike for a minute after filling it back up to prime the new filter. This will lower your oil level again and you have to top up a second time.
I filled mine up to the max line, and after priming the filter, the sight glass was almost empty again.
Did you wait for the oil to flow back down after running the engine to get a true reading?
SClown is offline
post #30 of 64 (permalink) Old 01-14-2013, 09:17 PM
Do what I did...
Just jab a flathead screwdriver through it... screwdriver to twist it off.
I like this. I mean dont fret about destroying the old filter; its only getting thrown out yeah?
by the way your red ninja looks awesome.
SClown is offline
Closed Thread
Ninja 300 DIY Video - Engine Oil Change cfrp Ninja 300 Service and Maintenance 7 11-05-2012 10:20 AM
What Would You Change IF You Could get the Manufacturer To Actually Listen HardRacing Ninja 300 General Discussion 10 10-19-2012 12:25 AM
