The clutch switch works because I had the bike on and put the kickstand down and it stopped the bike. Not only that I wouldn't be able to ride it if the switch was broke.
Now check your clutch switch.
Thats the kickstand switch that stops the bike when you put it down. So there is nothing wrong with your kickstand switch, as old3 mentioned right from the start, it is your clutch safety switch.
And the switch on the clutch doesnt stop you riding your bike, the only function it has is to allow you to start your bike if it is in gear, whilst you hold the clutch in. If your clutch is not in and you try to start the bike in gear, that switch is not activated and it will not allow you to start bike.
These are both similar safety functions. One stops you taking off with your kickstand down, one stops you from starting your bike in gear without the clutch engaged. If you have your clutch in, the bike is in gear, kickstand is up and it wont start, check this switch.
Two steps to find cause, always check kickstand switch first to eliminate as a problem as it is the simplest one:
1. Kickstand down, bike in neutral......try to start. When bike starts, put it in gear with kickstand still down. If it cuts out, your kickstand switch is fine. If bike is still running, your kickstand switch is no good.
2. Kickstand up, bike in gear, clutch held.........try to start. If no start, check clutch switch for correct operation. If it does start, clutch switch is fine.
