Help!! Stripped Studs While Swapping Sprocket - Kawasaki Ninja 300 Forum
post #1 of 11 (permalink) Old 06-12-2017, 02:51 AM Thread Starter
Hey guys,
I am pretty pissed off at this. I'm working on a complete rebuild (rebuild thread may be posted soon, see other posts for some details), and just when I'm almost finished, I decide to swap the rear sprocket for 40T. When I was test riding it through the neighborhood and making adjustments, I noticed first gear is useless, figured this would be a worthwhile upgrade. 8k RPM at 10mph is just annoying.
Anyway.. on to the actual point.. I go to torque down to the 44 ftlb spec. I use an impact drill to get it started, but not too much pressure, just enough to get the nut down the stud. Using a digital torque wrench (just bought it and will return it because it's useless), it showed that I got to 37 ftlb right before the nut started spinning relatively loosely. Backed it off, threads were completely smashed and ripped from the stud. Backed off another one that I tightened to about 37 lb on the opposite side, stud looked fine but threads on the nut were flattened. That's only two! I think that I compromised some other nuts. I went ahead and put some offers on salvage parts on eBay, but this just pisses me off.
My main question here is, should I go to about 35 lb and use blue loctite? I can't be the only one who's had this issue so far! I checked some R1/R6 forums and they were talking about the manual saying 76 lbs. They said they talked to dealership and were told 35ish lbs. Thats why I'm asking here, surely someone's experienced this on the Ninja or knows how to do this without crushing threads.
This is the one thing I've become desperate on. Everything else has had it's frustrating moments, but not like this where something broke and will continue to break. I'm desperate for help here. Thanks in advance for any input!
berguy is offline
post #2 of 11 (permalink) Old 06-12-2017, 08:29 AM
Sulman's Avatar
The first thing I'd say is, don't torque anything down with an impact wrench. It's stripped threads waiting to happen. You don't know what peak torque you put through the threads; it may have been well in excess of the stud's rating.
However, It happens. I haven't had this on my 300 but I've experienced it on another bike.
You'll just have to replace the studs and do it again. Torque them down with a conventional torque wrench. The studs should be good for 44 ft.lbs.
Sulman is offline
post #3 of 11 (permalink) Old 06-12-2017, 04:28 PM Thread Starter
I'm going to use my regular/hammer drill to gently put them back on. As far as taking them off though, do you think the impact is fine?
berguy is offline
post #4 of 11 (permalink) Old 06-12-2017, 06:24 PM
Sulman's Avatar
I took mine off with an impact driver when I changed the brake rotor last summer. It didn't seem to have any Ill effects.
It's possible that some fasteners are on way tight from the factory, and that can cause the threads to fail when they're retorqued.
Sulman is offline
post #5 of 11 (permalink) Old 06-12-2017, 07:15 PM
Wackeycat's Avatar
Just use your hand. Snug them down the use a good torque wrench and put them at. Spec.
There is almost no need to use power tools to put something ON.
Tighten them in a star pattern like you would a car tire.
Wackycat
Mods Done : Yes
Wackeycat is offline
post #6 of 11 (permalink) Old 06-13-2017, 02:56 AM Thread Starter
Thanks guys. I'm just lazy, ha. After rebuilding the thing, I can say that the power tools are nice to have as long as they're used with care. Granted, I just got my new driver and hammer drill in, and I did do most of the rebuild by hand. It really is tiring, these tools are huge helps. My mistake may have been carelessly using the impact driver, though I thought it was fairly gentle. Also possible is the crap torque wrench is off.
Anyway, how does one put new studs in? I managed to get the bad ones off by JB welding a nut on them and coming back 10 hours later to use the impact driver and get it off. Super easy. Do I just thread the ruined studs by hand, put the sprocket on, and then tighten to 44lbs? Or do I need to somehow tighten the studs down first?
berguy is offline
post #7 of 11 (permalink) Old 06-13-2017, 09:37 AM
Sulman's Avatar
I would go finger tight on the studs.
Sulman is offline
post #8 of 11 (permalink) Old 06-15-2017, 06:52 PM Thread Starter
I figured as much. I think when I torque down they will seat themselves.
Do you have an idea as to how to remove studs from another unit? I just received my salvage parts, but I need to remove these studs without damaging them!
The last time that I did this on my wheel, I used JB weld on the damaged studs. I don't want to mess up the new ones when transferring. Any ideas?
berguy is offline
post #9 of 11 (permalink) Old 06-15-2017, 08:39 PM
MAL
The safest way would be to use two nuts; just tighten them against each other, and use the inside nut to remove the stud.
Failing that you can {CAREFULLY} wrap the stud with some cloth or rag and use some vice-grips. BE CAREFUL though, as the threads on the stud will act as knives so they will cut through whatever you wrap the studs with. It's a matter of applying enough pressure as not to slip, but not too much to damage the threads.
MAL is offline
post #10 of 11 (permalink) Old 06-16-2017, 03:22 AM Thread Starter
Thanks!! Worked great.
Now my only concern is that the studs aren't all sticking out evenly. They are torques down to 44 ft lbs, but one of the studs in particular is showing more threads than others. Is this normal? Or concerning?
berguy is offline
Swapping Frame on 2016 Ninja 300 berguy Ninja 300 Service and Maintenance 9 05-21-2017 10:27 PM
Swapping PCV between different bike models/brands. Sedition Ninja 300 Parts & Accessories 2 03-29-2016 09:38 PM
HELP!! Stripped rear sprocket bolt xelar27 Ninja 300 Service and Maintenance 1 02-15-2016 11:11 PM
Swapping meter assembly - is there anything I should know before hand? whiskeythrottle Ninja 300 Issues and Troubleshooting 4 11-07-2015 11:58 AM
Swapping out Tank on Ninja 300 mikego_34 Ninja 300 General Discussion 10 05-06-2015 11:22 PM
