ABS light is ON every time when i start the bike - Kawasaki Ninja 300 Forum
  • 1 Post By minittowin
post #1 of 9 (permalink) Old 01-08-2017, 08:21 AM Thread Starter
Question ABS light is ON every time when i start the bike
Hello guys,
Just need to check if my ABS is normal, since everytime i ride the ABS indicator light is on, once the bike start moving it goes off again.. is this normal?? should i check it at the dealership. i've been told its fine since it goes of right after few meters, my friend's SE bike never had his ABS light on at all times..
Any idea folks?
Saifjo is offline
post #2 of 9 (permalink) Old 01-08-2017, 11:03 AM
That is normal, I think the ABS is not active until the bike gets up to about 3 MPH. My understanding is that the computer is waiting for input from the reluctor ring(s) before the ABS is active.
BadMoJoe is offline
post #3 of 9 (permalink) Old 01-08-2017, 04:22 PM
SnappyJB's Avatar
Mine does the same. It's normal
SnappyJB is offline
post #4 of 9 (permalink) Old 01-08-2017, 08:59 PM
FoxFire_1939's Avatar
This is normal, you need to get up to I think 5 km/h to get it to shut off.
FoxFire_1939 is offline
post #5 of 9 (permalink) Old 01-10-2017, 02:45 AM Thread Starter
Thanks guys! happy to know this is normal
Saifjo is offline
post #6 of 9 (permalink) Old 01-29-2017, 08:02 PM
Brion B's Avatar
Mine does the same.
2014 Ninja 300 SE Pearl StarDust White With ABS
Two Brothers Tarmac Carbon Slip On
TST Industries Integrated Taillight/Signal Lights
TST Industries Fender Delete Kit
K&N Air Filter
OEM TailBag
Adjustable Clutch/Brake Lever
2016 Vulcan 900 Custom
Cobra FI2000R Fuel Controller
Kuryakyn Voltmeter
Kawasaki Mini Tachometer
K&N Air Filter
Kuryakyn ISO Grips With Dual Throttle Bosses
Easybrackets
Cobra Freeway Bars
DesertDawg Freeway Bar Chaps
Mustang Wide Vintage Touring Seat With Drivers Backrest
Brion B is offline
post #7 of 9 (permalink) Old 01-29-2017, 09:20 PM
barberochris's Avatar
Think of it like a check engine light in a car. The pcm does self checks, basically checking for a signal within the appropriate range from various sensors. Once it gets the ok that no sensors are reading out the specified range it will shut off the CEL. Now for our abs bikes it is similar in that the computer is waiting for the wheel speed sensor to return a signal that indicates it is working. Once the bike is going a predetermined speed for x amount of distance (not too far obviously) it will see the sensor working properly. The movement is required because of the type of sensor it is. It sends an on/off sine wave that is squared off from "seeing" the tooth, hole, tooth, hole, etc. that we can see on the pickup disc mounted on the wheel. These sensors are usually electromagnetic and sense the break in their magnetic field.
barberochris is offline
post #8 of 9 (permalink) Old 01-30-2017, 03:53 AM
minittowin's Avatar
Read the owner's manual. It takes 2 minutes and there's all kinds of tidbits you should know or will need to know at some point. Oil, brake fluid, coolant, and how and when to check them, tire pressure, chain slack, headlight size, and lots of others.
cadd likes this.
Yoshi full exhaust, muffler bracket, and sliders, woodcraft clip-ons, 14/41, fender kit, DRIIs, K&N air and oil, removed snorkel, SSR preload adjusters, Ebay rearsets, levers, and windscreen, DID chain, RAM mount, custom USB port, integrated tail light, HID low beam, led parking lights, Super whatever Halogen hi beam, Double Sintered front and rear, mirror extenders, all balls head bearing and fork seals...
minittowin is offline
post #9 of 9 (permalink) Old 02-01-2017, 05:35 AM
It's worth mentioning that if the ABS light stays on once you're riding, there's potentially a fault.
snapdragon is offline
abs, indicator, light
Engine Light On :: Will Not Start Atticus27 Ninja 300 Issues and Troubleshooting 2 01-31-2016 03:10 PM
Question for ninja 300 ABS owners. ABS light on the dash asaulo1 Ninja 300 General Discussion 4 09-02-2015 12:51 PM
!#%^! 2nd time! (Bike won't start). 1Loyal New Rider Section 34 04-07-2015 08:35 PM
ABS Light on Brand new bike @ttaboy Ninja 300 Issues and Troubleshooting 7 08-02-2014 03:49 AM
Ninja 300 doesn't start after installing motodynamic integrated tail light - electric SON1C Ninja 300 Issues and Troubleshooting 6 05-21-2014 09:23 AM
